AutoCAD 2024 开发者帮助
CreateTypedArray 方法 (ActiveX)
2024-5-18 19:07| 发布者: admin| 查看: 721| 评论: 0|原作者: admin|来自: AutoCAD
创建一个包含类型化参数数组的变体。
object.CreateTypedArray VarArr, Type, Value1, [value2, value3, ...valueN]
类型: 实用程序
此方法应用到的对象。
VarArr
访问:仅输出
类型:变体
作为变体的值数组。
类型
访问:仅输入
类型:枚举VbVarType
您提供的值的类型。
vbBoolean或。vbIntegervbLongvbSinglevbDouble
值 1 [值 2, ...值N]
访问:仅输入
类型:在上面的 Type 参数中指定的类型。
要包含在变体中的值。
返回值 (RetVal)
无返回值。
生成的变体可以传递到任何接受数字数组作为变体的 AutoCAD 方法或特性中。
此方法只能使用后期绑定编程技术进行访问。若要使用此方法,请将对象定义为 ,而不是 。UtilityObject (Dim myObj As Object)AcadUtility
Sub Example_CreateTypedArray()
    ' This example creates a spline from variant arrays created
    ' from doubles using the CreateTypedArray method.
    ' Note that this method must be late bound. This is done
    ' by declaring the utility object (utilObj) as Object,
    ' not as AcadUtility.
    Dim splineObj As AcadSpline
    ' Even though these are arrays, they are declared as variants
    Dim startTan As Variant
    Dim endTan As Variant
    Dim fitPoints As Variant
    Dim utilObj As Object   ' Late bound object
    Set utilObj = ThisDrawing.Utility
    ' Define the spline.
    utilObj.CreateTypedArray startTan, vbDouble, 0.5, 0.5, 0
    utilObj.CreateTypedArray endTan, vbDouble, 0.5, 0.5, 0
    utilObj.CreateTypedArray fitPoints, vbDouble, 0, 0, 0, 5, 5, 0, 10, 0, 0
    ' Create the spline
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ZoomAll
(defun c:Example_CreateTypedArray()
    ;; This example creates a spline from variant arrays created
    ;; from doubles using the CreateTypedArray method.
    ;; Note that this method must be late bound. This is done
    ;; by declaring the utility object (utilObj) as Object,
    ;; not as AcadUtility.
    (setq utilObj (vla-get-Utility doc))
    ;; Define the spline.
    (vla-CreateTypedArray utilObj 'startTan vlax-vbDouble 0.5 0.5 0)
    (vla-CreateTypedArray utilObj 'endTan vlax-vbDouble 0.5 0.5 0)
    (vla-CreateTypedArray utilObj 'fitPoints vlax-vbDouble 0 0 0 5 5 0 10 0 0)
    ;; Create the spline
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
GMT+8, 2026-10-23 20:28
