AutoCAD 2024 开发者帮助
AngleToReal 方法 (ActiveX)
2024-5-18 19:07| 发布者: admin| 查看: 996| 评论: 0|原作者: admin|来自: AutoCAD
将角度转换为字符串,转换为实数(双精度)值。
RetVal = AngleToReal(Angle, Unit)
类型: 实用程序
此方法应用到的对象。
角度
访问:仅输入
类型:字符串
以字符串值表示的角度。
单位
访问:仅输入
类型:枚举AcAngleUnits
字符串将转换为的单位。
  • acDegrees
  • acDegreeMinuteSeconds
  • acGrads
  • acRadians
返回值 (RetVal)
类型:双
作为实数的角度。
Sub Example_AngleToReal()
    ' This example passes several different strings representing
    ' an angle in different units to be converted to radians.
    Dim angAsStr As String
    Dim unit As Integer
    Dim angAsReal As Double
    ' Convert the angle given in degrees unit to a real
    angAsStr = "45"
    unit = acDegrees
    angAsReal = ThisDrawing.Utility.AngleToReal(angAsStr, unit)
    MsgBox "45 degrees converts to " & angAsReal & " radians.", , "AngleAsReal Example"
    ' Convert the angle given in degrees/minutes/seconds unit to Radians
    angAsStr = "45d0' 0"""
    unit = acDegreeMinuteSeconds
    MsgBox "45 degrees, 0 minutes, 0 seconds converts to " & angAsReal & " radians.", , "AngleAsReal Example"
    ' Convert the angle given in grads unit to Radians
    angAsStr = "50"
    unit = acGrads
    MsgBox "50 grads converts to " & angAsReal & " radians.", , "AngleAsReal Example"
(defun c:Example_AngleToReal()
    ;; This example passes several different strings representing
    ;; an angle in different units to be converted to radians.
    ;; Convert the angle given in degrees unit to a real
    (setq angAsStr "45"
          unit acDegrees
          angAsReal (vla-AngleToReal (vla-get-Utility doc) angAsStr unit))
    (alert (strcat "45 degrees converts to " (rtos angAsReal 2) " radians."))
    ;; Convert the angle given in degrees/minutes/seconds unit to Radians
    (setq angAsStr "45d0' 0\""
          unit acDegreeMinuteSeconds
    (alert (strcat "45 degrees, 0 minutes, 0 seconds converts to " (rtos angAsReal 2) " radians."))
    ;; Convert the angle given in grads unit to Radians
    (setq angAsStr "50"
          unit acGrads
    (alert (strcat "50 grads converts to " (rtos angAsReal 2) " radians."))
GMT+8, 2026-10-23 09:17
