AddObject 方法 (ActiveX)
将对象添加到命名词典中。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddObject(Keyword, ObjectName)
言论此方法将 ObjectName 指定的新条目添加到字典中。如果该条目已存在,则将其替换为新对象。对象的名称由 Keyword 指定。 例如,可以将具有关键字“ThirdKeyword”和对象类型为“Object3”的对象添加到 MyDictionary 中以创建以下内容: 我的词典 关键字对象 FirstKeyword 对象 1 SecondKeyword 对象2 ThirdKeyword 对象3 注意:必须加载定义对象的 ObjectARX 应用程序,此方法才能正常运行。有关加载 ObjectARX 应用程序的信息,请参阅该方法。LoadARX
例子VBA: Sub Example_AddObject()
' This example creates a dictionary and adds
' a custom object to that dictionary.
Dim dictObj As AcadDictionary
Set dictObj = ThisDrawing.Dictionaries.Add("TEST_DICTIONARY")
' Load the ObjectARX application that defines the custom object.
' Note: The application listed here does not exist and
' will cause an error when run. Change the application name
' to the path and name of your ObjectARX application.
ThisDrawing.Application.LoadArx "MyARXApp.dll"
' Create the custom object in the dictionary
Dim keyName As String
Dim className As String
Dim customObj As AcadObject
keyName = "OBJ1"
className = "CAsdkDictObject"
Set customObj = dictObj.AddObject(keyName, className)
可视化 LISP: (vl-load-com)
(defun c:Example_AddObject()
;; This example creates a dictionary and adds
;; a custom object to that dictionary.
doc (vla-get-ActiveDocument acadObj)
dictionaries (vla-get-Dictionaries doc))
(setq dictObj (vla-Add dictionaries "TEST_DICTIONARY"))
;; Load the ObjectARX application that defines the custom object.
;; Note: The application listed here does not exist and
;; will cause an error when run. Change the application name
;; to the path and name of your ObjectARX application.
(vla-LoadArx acadObj "MyARXApp.dll")
;; Create the custom object in the dictionary
(setq keyName "OBJ1"
className "CAsdkDictObject")
(setq customObj (vla-AddObject dictObj keyName className))
GMT+8, 2026-10-28 02:36
