AddEllipticalCylinder 方法 (ActiveX)
创建一个 3D 实体椭圆柱体,其底位于 WCS 的 XY 平面上,给定 Center、MajorRadius、MinorRadius 和 Height。 支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持 签名VBA: RetVal = object.AddEllipticalCylinder(Center, MajorRadius, MinorRadius, Height) 言论没有其他评论。 例子VBA: Sub Example_AddEllipticalCylinder()
' This example creates an elliptical cylinder in model space.
Dim cylinderObj As Acad3DSolid
Dim center(0 To 2) As Double
Dim majorRadius As Double
Dim minorRadius As Double
Dim height As Double
' Define the elliptical cylinder
center(0) = 0#: center(1) = 0#: center(2) = 0#
majorRadius = 5#
minorRadius = 2.5
height = 10#
' Create the elliptical cylinder in model space
Set cylinderObj = ThisDrawing.ModelSpace.AddEllipticalCylinder(center, majorRadius, minorRadius, height)
' Change the viewing direction of the viewport to better see the cylinder
Dim NewDirection(0 To 2) As Double
NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
ThisDrawing.ActiveViewport.direction = NewDirection
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_AddEllipticalCylinder()
;; This example creates an elliptical cylinder in model space.
;; Define the elliptical cylinder
(setq center (vlax-3d-point 0 0 0)
majorRadius 5
minorRadius 2.5
height 10)
;; Create the elliptical cylinder in model space
(setq cylinderObj (vla-AddEllipticalCylinder modelSpace center majorRadius minorRadius height))
;; Change the viewing direction of the viewport to better see the cylinder
(setq NewDirection (vlax-3d-point -1 -1 1))
(setq activeViewport (vla-get-ActiveViewport doc))
(vla-put-Direction activeViewport NewDirection)
(vla-put-ActiveViewport doc activeViewport)
(vla-ZoomAll acadObj)
GMT+8, 2026-10-31 05:55
