AddCustomObject 方法 (ActiveX)
创建自定义对象。 支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持 签名VBA: RetVal = object.AddCustomObject(ClassName) 返回值 (RetVal)类型:自定义对象 新创建的 Custom 对象。 言论必须加载定义 rxClassName 定制类的 ObjectARX DLL。在 Application 对象上使用 LoadARX 方法显式加载 ObjectARX 文件。 例子VBA: Sub Example_AddCustomObject()
' This example adds a custom object to model space.
' Load the ObjectARX application that defines the custom object.
' Note: The application listed here does not exist and
' will cause an error when run. Change the application name
' to the path and name of your ObjectARX Application.
ThisDrawing.Application.LoadArx "MyARXApp.dll"
' Once the application has been loaded successfully,
' add the custom object to model space.
Dim customObj As AcadObject
Set customObj = ThisDrawing.ModelSpace.AddCustomObject("MyNewObject")
可视化 LISP: (vl-load-com)
(defun c:Example_AddCustomObject()
;; This example adds a custom object to model space.
;; Load the ObjectARX application that defines the custom object.
;; Note: The application listed here does not exist and
;; will cause an error when run. Change the application name
;; to the path and name of your ObjectARX Application.
(vla-LoadArx acadObj "MyARXApp.dll")
;; Once the application has been loaded successfully,
;; add the custom object to model space.
(setq customObj (vla-AddCustomObject (vla-get-ModelSpace doc) "MyNewObject"))
GMT+8, 2026-10-23 08:32
