AutoCAD 2024 开发者帮助
Add3DMesh 方法 (ActiveX)
2024-5-18 19:07| 发布者: admin| 查看: 862| 评论: 0|原作者: admin|来自: AutoCAD
根据 M 和 N 方向上的点数以及 M 和 N 方向上的点坐标,创建自由形式的 3D 网格。
支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持
RetVal = object.Add3Dmesh(M, N, PointsMatrix)
类型:块、模型空间、纸空间
此方法应用到的对象。
男,北
访问:仅输入
类型:整数
点数组的尺寸。M 和 N 方向上的网格尺寸限制在 2 到 256 之间。
点矩阵
访问:仅输入
类型:变体(双打数组)
3D WCS 坐标的 M x N 矩阵。定义顶点从顶点 (0,0) 开始。在指定行 M + 1 中的顶点之前,必须为行 M 中的每个顶点提供坐标位置。
返回值 (RetVal)
类型:PolygonMesh
A 作为新创建的 3DMesh 对象。PolygonMesh
顶点可以是彼此之间的任意距离。
A 在 M 和 N 方向上始终打开。创建网格后,可以使用对象上的 and 属性关闭网格。PolygonMeshMCloseNClosePolygonMesh
A 始终创建为简单网格。创建网格后,可以使用该属性进行平滑处理。PolygonMeshType
Sub Example_Add3DMesh()
    ' This example creates a 4 X 4 polygonmesh in model space.
    Dim meshObj As AcadPolygonMesh
    Dim mSize, nSize, count As Integer
    Dim points(0 To 47) As Double
    ' Create the matrix of points
    points(0) = 0: points(1) = 0: points(2) = 0
    points(3) = 2: points(4) = 0: points(5) = 1
    points(6) = 4: points(7) = 0: points(8) = 0
    points(9) = 6: points(10) = 0: points(11) = 1
    points(12) = 0: points(13) = 2: points(14) = 0
    points(15) = 2: points(16) = 2: points(17) = 1
    points(18) = 4: points(19) = 2: points(20) = 0
    points(21) = 6: points(22) = 2: points(23) = 1
    points(24) = 0: points(25) = 4: points(26) = 0
    points(27) = 2: points(28) = 4: points(29) = 1
    points(30) = 4: points(31) = 4: points(32) = 0
    points(33) = 6: points(34) = 4: points(35) = 0
    points(36) = 0: points(37) = 6: points(38) = 0
    points(39) = 2: points(40) = 6: points(41) = 1
    points(42) = 4: points(43) = 6: points(44) = 0
    points(45) = 6: points(46) = 6: points(47) = 0
    mSize = 4: nSize = 4
    ' creates a 3Dmesh in model space
    Set meshObj = ThisDrawing.ModelSpace.Add3DMesh(mSize, nSize, points)
    ' Change the viewing direction of the viewport to better see the polygonmesh
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ZoomAll
(defun c:Example_Add3DMesh()
    ;; This example creates a 4 X 4 polygonmesh in model space.
    ;; Create the matrix of points
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 47)))
    (vlax-safearray-fill points '(0 0 0
                                  2 0 1
                                  4 0 0
                                  6 0 1
                                  0 2 0
                                  2 2 1
                                  4 2 0
                                  6 2 1
                                  0 4 0
                                  2 4 1
                                  4 4 0
                                  6 4 0
                                  0 6 0
                                  2 6 1
                                  4 6 0
                                  6 6 0
    (setq mSize 4
	         nSize 4)
    ;; creates a 3Dmesh in model space
    (setq meshObj (vla-Add3DMesh modelSpace mSize nSize points))
    ;; Change the viewing direction of the viewport to better see the polygonmesh
    (setq NewDirection (vlax-3d-point -1 -1 1))
    (setq activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport NewDirection)
    (vla-put-ActiveViewport doc activeViewport)
    (vla-ZoomAll acadObj)
GMT+8, 2026-10-22 13:05
