AutoCAD 2024 开发者帮助
关于编辑 3D 实体 (VBA/ActiveX)
2024-5-18 19:06| 发布者: admin| 查看: 863| 评论: 0|原作者: admin|来自: AutoCAD
您可以通过组合、减去和 3D 实体的交集来创建复杂形状。
注意:AutoCAD LT for Windows 对修改三维实体的支持有限。
您可以连接实体、相互减去实体或求实体的公共体积(重叠部分)。使用 or 方法执行这些组合。BooleanCheckInterference
通过获得实体的 2D 横截面或将实体切成两块来进一步修改实体。使用该方法求固体的横截面,以及将实体切成两块的方法。SectionSolidSliceSolid
求出两个实体之间的干涉
本示例在模型空间中创建一个方框和一个圆柱体。然后,它找到两个固体之间的干涉,并从该干涉中创建一个新的固体。为了便于查看,盒子是白色的,圆柱体是青色的,干涉固体是红色的。
Sub Ch8_FindInterferenceBetweenSolids()
    ' Define the box
    Dim boxObj As Acad3DSolid
    Dim length As Double
    Dim width As Double
    Dim height As Double
    Dim center(0 To 2) As Double
    center(0) = 5: center(1) = 5: center(2) = 0
    length = 5
    width = 7
    height = 10
    ' Create the box object in model space
    ' and color it white
    Set boxObj = ThisDrawing.ModelSpace. _
 AddBox(center, length, width, height)
    boxObj.Color = acWhite
    ' Define the cylinder
    Dim cylinderObj As Acad3DSolid
    Dim cylinderRadius As Double
    Dim cylinderHeight As Double
    center(0) = 0: center(1) = 0: center(2) = 0
    cylinderRadius = 5
    cylinderHeight = 20
    ' Create the Cylinder and
    ' color it cyan
    Set cylinderObj = ThisDrawing.ModelSpace.AddCylinder _
 (center, cylinderRadius, cylinderHeight)
    cylinderObj.Color = acCyan
    ' Find the interference between the two solids
    ' and create a new solid from it. Color the
    ' new solid red.
    Dim solidObj As Acad3DSolid
    Dim bSolidsInterfere As Boolean
    Set solidObj = boxObj.CheckInterference(cylinderObj, True, bSolidsInterfere)
    solidObj.Color = acRed
    ZoomAll
将固体切成两个固体
本示例在模型空间中创建一个框。然后,它根据由三个点定义的平面对盒子进行切片。切片以 .3DSolid
Sub Ch8_SliceABox()
    Dim width As Double
    center(0) = 5#: center(1) = 5#: center(2) = 0
    length = 5#: width = 7: height = 10#
    ' Create the box (3DSolid) object in model space
    ' Define the section plane with three points
    Dim slicePt1(0 To 2) As Double
    Dim slicePt2(0 To 2) As Double
    Dim slicePt3(0 To 2) As Double
    slicePt1(0) = 1.5: slicePt1(1) = 7.5: slicePt1(2) = 0
    slicePt2(0) = 1.5: slicePt2(1) = 7.5: slicePt2(2) = 10
    slicePt3(0) = 8.5: slicePt3(1) = 2.5: slicePt3(2) = 10
    ' slice the box and color the new solid red
    Dim sliceObj As Acad3DSolid
    Set sliceObj = boxObj.SliceSolid _
 (slicePt1, slicePt2, slicePt3, True)
    sliceObj.Color = acRed
    ZoomAll
GMT+8, 2026-11-2 11:13
