关于创建多面网格 (VBA/ActiveX)
使用该方法创建多面网格,每个面能够具有多个顶点。AddPolyfaceMesh 注意:AutoCAD LT for Windows 不支持创建三维网格。
创建多面网格类似于创建矩形网格。要创建多面网格,请指定其所有顶点的坐标,然后通过输入该面的所有顶点的顶点号来定义每个面。创建多面网格时,可以将特定边设置为不可见,将其指定给图层,或为其赋予颜色。 要使边不可见,请输入边的顶点数作为负值。 创建多面网格此示例在模型空间中创建一个对象。更新了活动视口的查看方向,以便更轻松地显示网格的三维性质。PolyfaceMesh Sub Ch8_CreatePolyfaceMesh()
'Define the mesh vertices
Dim vertex(0 To 17) As Double
vertex(0) = 4: vertex(1) = 7: vertex(2) = 0
vertex(3) = 5: vertex(4) = 7: vertex(5) = 0
vertex(6) = 6: vertex(7) = 7: vertex(8) = 0
vertex(9) = 4: vertex(10) = 6: vertex(11) = 0
vertex(12) = 5: vertex(13) = 6: vertex(14) = 0
vertex(15) = 6: vertex(16) = 6: vertex(17) = 1
' Define the face list
Dim FaceList(0 To 7) As Integer
FaceList(0) = 1
FaceList(1) = 2
FaceList(2) = 5
FaceList(3) = 4
FaceList(4) = 2
FaceList(5) = 3
FaceList(6) = 6
FaceList(7) = 5
' Create the polyface mesh
Dim polyfaceMeshObj As AcadPolyfaceMesh
Set polyfaceMeshObj = ThisDrawing.ModelSpace.AddPolyfaceMesh _
(vertex, FaceList)
' Change the viewing direction of the viewport to
' better see the polyface mesh
Dim NewDirection(0 To 2) As Double
NewDirection(0) = -1
NewDirection(1) = -1
NewDirection(2) = 1
ThisDrawing.ActiveViewport.direction = NewDirection
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
ZoomAll
GMT+8, 2026-10-22 11:19
