AutoCAD 2024 开发者帮助
关于定义缩放窗口 (ActiveX)
2024-5-18 19:06| 发布者: admin| 查看: 1013| 评论: 0|原作者: admin|来自: AutoCAD
关于定义缩放窗口 (ActiveX)
您可以通过指定定义某个区域的角来快速放大该区域。
若要通过指定区域边界来放大区域,请使用 or 方法。该方法允许您以编程方式定义表示缩放窗口的两个点。该方法要求用户选择两个点。这两个选取的点成为缩放窗口。ZoomWindowZoomPickWindowZoomWindowZoomPickWindow
将活动图形缩放到由两个点定义的窗口
AutoLISP
(defun c:Ch3_ZoomWindow()
    ;; ZoomWindow
    (alert (strcat "Perform a ZoomWindow with:\n"
                   "1.3, 7.8, 0\n"
                   "13.7, -2.6, 0"))
    (setq point1 (vlax-3d-point 1.3 7.8 0)
          point2 (vlax-3d-point 13.7 -2.6 0))
    (vla-ZoomWindow acadObj point1 point2)
    ;; ZoomPickWindow
    (alert  "Perform a ZoomPickWindow")
    (vla-ZoomPickWindow acadObj)
VBA(仅限 AutoCAD)
Sub Ch3_ZoomWindow()
  ' ZoomWindow
  MsgBox "Perform a ZoomWindow with:" & vbCrLf & _
  "1.3, 7.8, 0" & vbCrLf & _
  "13.7, -2.6, 0", , "ZoomWindow"
  Dim point1(0 To 2) As Double
  Dim point2(0 To 2) As Double
  point1(0) = 1.3: point1(1) = 7.8: point1(2) = 0
  point2(0) = 13.7: point2(1) = -2.6: point2(2) = 0
  ThisDrawing.Application.ZoomWindow point1, point2
  ' ZoomPickWindow
  MsgBox "Perform a ZoomPickWindow", , "ZoomPickWindow"
  ThisDrawing.Application.ZoomPickWindow
GMT+8, 2026-10-23 13:49
