AutoCAD 2024 开发者帮助
AutoCAD 2000i API 历史记录参考 (ActiveX)
2024-5-18 19:06| 发布者: admin| 查看: 875| 评论: 0|原作者: admin|来自: AutoCAD
对 AutoCAD 2000i 和基于 AutoCAD 2000i 的产品中的 ActiveX API 所做的添加和更改。
枚举
AcLayerStateMask (New)
        acLsNone = 0
        acLsOn = 1
        acLsFrozen = 2
        acLsLocked = 4
        acLsPlot = 8
        acLsNewViewport = 16
        acLsColor = 32
        acLsLineType = 64
        acLsLineWeight = 128
        acLsPlotStyle = 256
        acLsAll = 65535
类
IAcadLayerStateManager (New)
        SetDatabase - Method
        Mask - Property
        Save - Method
        Restore - Method
        Delete - Method
        Rename - Method
        Import - Method
        Export - Method
GMT+8, 2026-10-23 18:22
