AutoCAD 2024 开发者帮助
AutoCAD 2022 API 历史记录参考 (ActiveX)
2024-5-18 19:06| 发布者: admin| 查看: 1038| 评论: 0|原作者: admin|来自: AutoCAD
对 AutoCAD 2022 和基于 AutoCAD 2022 的产品中的 ActiveX API 所做的添加和更改。
类
AcadApplication
        Minor version number of the class has been incremented from 24.0 to 24.1
        Use the ProgID AutoCAD.Application.24.1 to create an instance of AutoCAD 2022 or
        ProgID AutoCAD.Application.24.0 to create an instance of AutoCAD 2021, when installed.
        ProgID AutoCAD.Application.24 can still be used to create an instance of AutoCAD 2022, but
        there will be inconsistencies in execution when installed side-by-side with AutoCAD 2021.
GMT+8, 2026-10-24 13:44
