AutoCAD 2024 开发者帮助
了解 gp:RedefinePolyBorder 函数 (AutoLISP)
2024-5-18 19:06| 发布者: admin| 查看: 1028| 评论: 0|原作者: admin|来自: AutoCAD
以下伪代码显示了 main 函数背后的逻辑:gp:RedefinePolyBorder
Function gp:RedefinePolyBorder
   Extract the previous polyline corner points (12, 13, 14, and 15
     key values).
   Find the moved corner point by comparing the previous
     polyline corner points with the current corner points.
     (The one "misfit" point will be the point that moved.)
   Set the new corner points by recalculating the two points
     adjacent to the moved point.
   Update the new corner points in the reactor data (that will
     be stored back in the reactor for the modified polyline).
   Update other information in the reactor data. (Start point,
      endpoint, width, and length of path need to be recalculated.)
End Function
GMT+8, 2026-10-22 11:08
