创建 Line 对象 (.NET)
本示例将一条从 (5,5,0) 开始,到 (12,3,0) 结束的线添加到模型空间。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("AddLine")> _
Public Sub AddLine()
'' Start a transaction
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a line that starts at 5,5 and ends at 12,3
Using acLine As Line = New Line(New Point3d(5, 5, 0), _
New Point3d(12, 3, 0))
acBlkTblRec.AppendEntity(acLine)
acTrans.AddNewlyCreatedDBObject(acLine, True)
End Using
'' Save the new object to the database
acTrans.Commit()
End Using
[CommandMethod("AddLine")]
public static void AddLine()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a line that starts at 5,5 and ends at 12,3
using (Line acLine = new Line(new Point3d(5, 5, 0),
new Point3d(12, 3, 0)))
acBlkTblRec.AppendEntity(acLine);
acTrans.AddNewlyCreatedDBObject(acLine, true);
// Save the new object to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub AddLine()
' Define the start point
Dim ptStr(0 To 2) As Double
ptStr(0) = 5: ptStr(1) = 5: ptStr(2) = 0#
' Define the end point
Dim ptEnd(0 To 2) As Double
ptEnd(0) = 12: ptEnd(1) = 3: ptEnd(2) = 0#
' Create a Line object in model space
Dim lineObj As AcadLine
Set lineObj = ThisDrawing.ModelSpace.AddLine(ptStr, ptEnd)
相关概念父主题: |
GMT+8, 2026-10-23 00:55
