确定父对象 (.NET)
图形对象将追加到对象,例如“模型”或“图纸空间”。您可以通过对象引用表示 Model 和 Paper 空间的块。如果要在当前空间而不是特定空间中工作,请从具有该属性的当前数据库中获取当前空间的 ObjectId。BlockTableRecordBlockTableCurrentSpaceId 可以使用命名空间下类的属性或 and 方法从对象中检索 Model 和 Paper 空间的块表记录的 ObjectId。BlockTableGetBlockModelSpaceIdGetBlockPaperSpaceIdSymbolUtilityServicesDatabaseServices 访问模型空间、图纸空间或当前空间以下示例演示如何访问与模型空间、图纸空间或当前空间关联的块表记录。引用块表记录后,将向块表记录添加新行。 VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("AccessSpace")> _
Public Sub AccessSpace()
'' Start a transaction
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
'' Open the Block table record for read
'' Request which table record to open
Dim pKeyOpts As PromptKeywordOptions = New PromptKeywordOptions("")
pKeyOpts.Message = vbLf & "Enter which space to create the line in "
pKeyOpts.Keywords.Add("Model")
pKeyOpts.Keywords.Add("Paper")
pKeyOpts.Keywords.Add("Current")
pKeyOpts.AllowNone = False
pKeyOpts.AppendKeywordsToMessage = True
Dim pKeyRes As PromptResult = acDoc.Editor.GetKeywords(pKeyOpts)
If pKeyRes.StringResult = "Model" Then
'' Get the ObjectID for Model space from the Block table
OpenMode.ForWrite)
ElseIf pKeyRes.StringResult = "Paper" Then
'' Get the ObjectID for Paper space from the Block table
acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.PaperSpace), _
OpenMode.ForWrite)
Else
'' Get the ObjectID for the current space from the database
acBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, _
OpenMode.ForWrite)
End If
'' Create a line that starts at 2,5 and ends at 10,7
Using acLine As Line = New Line(New Point3d(2, 5, 0), _
New Point3d(10, 7, 0))
acBlkTblRec.AppendEntity(acLine)
acTrans.AddNewlyCreatedDBObject(acLine, True)
End Using
'' Save the new line to the database
acTrans.Commit()
End Using
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("AccessSpace")]
public static void AccessSpace()
// Start a transaction
BlockTable acBlkTbl;
// Open the Block table record for read
BlockTableRecord acBlkTblRec;
// Request which table record to open
PromptKeywordOptions pKeyOpts = new PromptKeywordOptions("");
pKeyOpts.Message = "\nEnter which space to create the line in ";
pKeyOpts.Keywords.Add("Model");
pKeyOpts.Keywords.Add("Paper");
pKeyOpts.Keywords.Add("Current");
pKeyOpts.AllowNone = false;
pKeyOpts.AppendKeywordsToMessage = true;
PromptResult pKeyRes = acDoc.Editor.GetKeywords(pKeyOpts);
if (pKeyRes.StringResult == "Model")
// Get the ObjectID for Model space from the Block table
else if (pKeyRes.StringResult == "Paper")
// Get the ObjectID for Paper space from the Block table
acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.PaperSpace],
else
// Get the ObjectID for the current space from the database
// Create a line that starts at 2,5 and ends at 10,7
using (Line acLine = new Line(new Point3d(2, 5, 0),
new Point3d(10, 7, 0)))
acBlkTblRec.AppendEntity(acLine);
acTrans.AddNewlyCreatedDBObject(acLine, true);
// Save the new line to the database
acTrans.Commit();
VBA/ActiveX 代码参考Public Sub AccessSpace()
' Define the valid keywords
Dim keywordList As String
keywordList = "Model Paper Current"
' Call InitializeUserInput to setup the keywords
ThisDrawing.Utility.InitializeUserInput 1, keywordList
' Get the user input
Dim retVal As Variant
retVal = ThisDrawing.Utility.GetKeyword(vbLf & _
"Enter which space to create the line in " & _
"[Model/Paper/Current]: ")
' Get the entered keyword
Dim strVal As String
strVal = ThisDrawing.Utility.GetInput
Dim acSpaceObj As Object
If strVal = "Model" Or _
(strVal = "Current" And ThisDrawing.ActiveSpace = acModelSpace) Then
'' Get the Model space object
Set acSpaceObj = ThisDrawing.ModelSpace
Else
'' Get the Paper space object
Set acSpaceObj = ThisDrawing.PaperSpace
End If
Dim acLine As AcadLine
Dim dPtStr(0 To 2) As Double
dPtStr(0) = 2: dPtStr(1) = 5: dPtStr(2) = 0#
Dim dPtEnd(0 To 2) As Double
dPtEnd(0) = 10: dPtEnd(1) = 7: dPtEnd(2) = 0#
Set acLine = acSpaceObj.AddLine(dPtStr, dPtEnd)
相关概念父主题: |
GMT+8, 2026-10-23 06:40
