GetPoint 方法 (.NET)
2024-5-18 19:01| 发布者: admin| 查看: 671| 评论: 0|原作者: admin|来自: AutoCAD
GetPoint 方法 (.NET)
该方法提示用户在命令提示符下指定一个点。该对象允许您控制输入的输入以及提示消息的显示方式。对象的 和 属性控制是否从基点绘制橡皮筋线。该对象的属性允许您定义除了指定点之外还可以在命令提示符下输入的关键字。GetPointPromptPointOptionsUseBasePointBasePointPromptPointOptionsKeywordsPromptPointOptions
获取用户选择的点
下面的示例提示用户输入两个点,然后使用这些点作为起点和终结点绘制一条线。
VB.NET
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("GetPointsFromUser")> _
Public Sub GetPointsFromUser()
    '' Get the current database and start the Transaction Manager
    Dim pPtRes As PromptPointResult
    Dim pPtOpts As PromptPointOptions = New PromptPointOptions("")
    '' Prompt for the start point
    pPtOpts.Message = vbLf & "Enter the start point of the line: "
    pPtRes = acDoc.Editor.GetPoint(pPtOpts)
    Dim ptStart As Point3d = pPtRes.Value
    '' Exit if the user presses ESC or cancels the command
    If pPtRes.Status = PromptStatus.Cancel Then Exit Sub
    '' Prompt for the end point
    pPtOpts.Message = vbLf & "Enter the end point of the line: "
    pPtOpts.UseBasePoint = True
    pPtOpts.BasePoint = ptStart
    Dim ptEnd As Point3d = pPtRes.Value
    '' Start a transaction
        Dim acBlkTbl As BlockTable
        '' Open Model space for write
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Define the new line
        Using acLine As Line = New Line(ptStart, ptEnd)
            '' Add the line to the drawing
            acBlkTblRec.AppendEntity(acLine)
            acTrans.AddNewlyCreatedDBObject(acLine, True)
        End Using
        '' Zoom to the extents or limits of the drawing
        acDoc.SendStringToExecute("._zoom _all ", True, False, False)
        '' Commit the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("GetPointsFromUser")]
public static void GetPointsFromUser()
    // Get the current database and start the Transaction Manager
    PromptPointResult pPtRes;
    PromptPointOptions pPtOpts = new PromptPointOptions("");
    // Prompt for the start point
    pPtOpts.Message = "\nEnter the start point of the line: ";
    pPtRes = acDoc.Editor.GetPoint(pPtOpts);
    Point3d ptStart = pPtRes.Value;
    // Exit if the user presses ESC or cancels the command
    if (pPtRes.Status == PromptStatus.Cancel) return;
    // Prompt for the end point
    pPtOpts.Message = "\nEnter the end point of the line: ";
    pPtOpts.UseBasePoint = true;
    pPtOpts.BasePoint = ptStart;
    Point3d ptEnd = pPtRes.Value;
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Open Model space for write
        // Define the new line
        using (Line acLine = new Line(ptStart, ptEnd))
            // Add the line to the drawing
            acBlkTblRec.AppendEntity(acLine);
            acTrans.AddNewlyCreatedDBObject(acLine, true);
        // Zoom to the extents or limits of the drawing
        acDoc.SendStringToExecute("._zoom _all ", true, false, false);
        // Commit the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
    Dim startPnt As Variant
    Dim endPnt As Variant
    Dim prompt1 As String
    Dim prompt2 As String
    prompt1 = vbCrLf & "Enter the start point of the line: "
    prompt2 = vbCrLf & "Enter the end point of the line: "
    ' Get the first point without entering a base point
    startPnt = ThisDrawing.Utility.GetPoint(, prompt1)
    ' Use the point entered above as the base point
    endPnt = ThisDrawing.Utility.GetPoint(startPnt, prompt2)
    ' Create a line using the two points entered
    ThisDrawing.ModelSpace.AddLine startPnt, endPnt
GMT+8, 2026-10-23 08:16
