应用程序密钥
此密钥适用于想要注册自己并参与 DesignCenter 自定义模式的内容提供商。 应用程序名称DesignCenter 需要从参与其自定义模式的内容提供商处获得的所有信息都存储在此密钥下。密钥的名称将是应用程序的名称,因为它显示在自定义模式中。在“应用程序名称”项下可以是以下子项:
以下注册表值演示了应用程序注册表分支: [HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R24.2\ ACAD-6101:409\AutodeskApps\AcadDC\Applications\Autodesk\Finder\Drawings] "LocalName"="Drawings" "File Based Search"=dword:00000001 "Advanced Search"=dword:00000001 "Date Search"=dword:00000001 "Date Available"=dword:00000001 "Size Available"=dword:00000001 "Extension"=".dwg" "Auto Append"=dword:00000001 [HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R24.2\ ACAD-6101:409\AutodeskApps\AcadDC\Applications\Autodesk\Finder\Drawings \Advanced Properties] "Advanced Property1"="Block name" "Advanced Property2"="Block and drawing description" "Advanced Property3"="Attribute tag" "Advanced Property4"="Attribute value" [HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R24.2\ ACAD-6101:409\AutodeskApps\AcadDC\Applications\Autodesk\Finder\Drawings \Properties] "Property1"="File Name" "Property2"="Title" "Property3"="Subject" "Property4"="Author" "Property5"="Keywords" |
GMT+8, 2026-10-23 01:13
