示例 3:获取窗口坐标
此示例演示如何使用 和 获取视口的显示坐标。当您绘制依赖于视口的物理布局的图形时,此功能非常方便,例如随视口的大小或边框而变化的图标和标记。绘制的图形将随着平移和缩放而变化。AcGiViewportDraw::polylineDc()AcGiViewport::getViewportDcCorners() 该示例在视口的右上角绘制一个框。框的宽度和高度始终是视口最短尺寸的十分之一,并且框位于视口右上角左侧的视口最短尺寸的十分之一的中心: void
AsdkIconSamp::subViewportDraw(AcGiViewportDraw* pV)
// Get the current viewport's display coordinates.
AcGePoint2d lower_left, upper_right;
pV->viewport ().getViewportDcCorners(lower_left,
upper_right);
double xsize = upper_right.x - lower_left.x;
double ysize = upper_right.y - lower_left.y;
xsize /= 10.0;
ysize /= 10.0;
double xcenter = upper_right.x - xsize;
double ycenter = upper_right.y - ysize;
double half_xsize = xsize / 2.0;
double half_ysize = ysize / 2.0;
// Create a unit square.
const int num_verts = 5;
AcGePoint3d verts[num_verts];
for (int i = 0; i < num_verts; i++) {
verts[i].x = xcenter;
verts[i].y = ycenter;
verts[i].z = 0.0;
verts[0].x -= half_xsize;
verts[0].y += half_ysize;
verts[1].x += half_xsize;
verts[1].y += half_ysize;
verts[2].x += half_xsize;
verts[2].y -= half_ysize;
verts[3].x -= half_xsize;
verts[3].y -= half_ysize;
verts[4] = verts[0];
pV- >subEntityTraits().setColor(kRed);
pV->geometry ().polylineDc(num_verts, verts);
void
AsdkIconSamp::viewportDraw(AcGiViewportDraw* pV)
pV->viewport().getViewportDcCorners(lower_left,
upper_right);
xsize /= 10.0;
ysize /= 10.0;
verts[i].z = 0.0;
pV->subEntityTraits().setColor(kRed);
pV->geometry().polylineDc(num_verts, verts);
父主题: |
GMT+8, 2026-10-22 21:42
