协议扩展示例
2024-5-18 19:01| 发布者: admin| 查看: 741| 评论: 0|原作者: admin|来自: AutoCAD
协议扩展示例
此协议扩展示例分为三个部分:
  • 四个协议扩展类的声明和定义:、、 和AsdkEntTemperatureAsdkDefaultTemperatureAsdkRegionTemperatureAsdkCircleTemperature.
  • ENERGY 命令函数的实现,它允许用户选择一个实体,然后计算该实体的温度。energy()
  • ObjectARX 模块接口函数:、 和 。initApp()unloadApp()acrxEntryPoint()
// This is the AsdkEntTemperature protocol extension abstract base
// class. Notice that this is the lowest level that uses
// the ACRX macros.
class AsdkEntTemperature : public AcRxObject
public:
    ACRX_DECLARE_MEMBERS(AsdkEntTemperature);
    virtual double reflectedEnergy(AcDbEntity*) const = 0;
ACRX_NO_CONS_DEFINE_MEMBERS(AsdkEntTemperature, AcRxObject);
// This is the default implementation to be attached to AcDbEntity
// as a catch-all. This guarantees that this protocol extension will
// be found for any entity, so the search up the AcRxClass tree will
// not fail and abort AutoCAD.
class AsdkDefaultTemperature : public AsdkEntTemperature
public:
    virtual double reflectedEnergy(AcDbEntity* pEnt) const;
double
AsdkDefaultTemperature::reflectedEnergy(
    acutPrintf(
        "\nThis entity has no area, and no reflection.\n");
    return -1.0;
// AsdkEntTemperature implementation for Regions
class AsdkRegionTemperature : public AsdkEntTemperature
public:
double
AsdkRegionTemperature::reflectedEnergy(
    AcDbRegion *pRegion = AcDbRegion::cast(pEnt);
    if (pRegion == NULL)
        acutPrintf("\nThe impossible has happened!");
    // Compute the reflected energy as the region area multiplied
    // by a dummy constant.
    double retVal;
    if (pRegion->getArea(retVal) != Acad::eOk)
        return -1.0;
    return retVal * 42.0;
// AsdkEntTemperature implementation for circles
class AsdkCircleTemperature : public AsdkEntTemperature
public:
double
AsdkCircleTemperature::reflectedEnergy(
    AcDbCircle *pCircle = AcDbCircle::cast(pEnt);
    // Compute the reflected energy in a manner distinctly
    // different than for AcDbRegion.
    return pCircle->radius() * 6.21 * 42.0;
// This function has the user select an entity and then
// calls the reflectedEnergy() function in the protocol
// extension class attached to that entity's class.
void
energy()
    AcDbEntity *pEnt;
    AcDbObjectId pEntId;
    ads_name en;
    ads_point pt;
    if (acedEntSel("\nSelect an Entity:  ", en, pt)
        != RTNORM)
        acutPrintf("Nothing Selected\n");
        return;
    acdbGetObjectId(pEntId, en);
    acdbOpenObject(pEnt, pEntId, AcDb::kForRead);
    // call the protocol extension class's method
    double eTemp = ACRX_X_CALL(pEnt,
        AsdkEntTemperature)->reflectedEnergy(pEnt);
    acutPrintf("\nEnergy == %f\n", eTemp);
    pEnt->close();
// Pointers for protocol extension objects. These pointers
// are global so that they can be accessed during
// initialization and cleanup.
AsdkDefaultTemperature *pDefaultTemp;
AsdkRegionTemperature *pRegionTemp;
AsdkCircleTemperature *pCircleTemp;
// Initialization function called from acrxEntryPoint() during
// kInitAppMsg case. This function is used to add commands
// to the command stack and to add protocol extension
// objects to classes.
void
initApp()
    acrxRegisterService("AsdkTemperature");
    AsdkEntTemperature::rxInit();
    acrxBuildClassHierarchy();
    pDefaultTemp = new AsdkDefaultTemperature();
    pRegionTemp = new AsdkRegionTemperature();
    pCircleTemp = new AsdkCircleTemperature();
    // Add the protocol extension objects to the appropriate
    // AcRxClass objects.
    AcDbEntity::desc()->addX(AsdkEntTemperature::desc(),
        pDefaultTemp);
    AcDbRegion::desc()->addX(AsdkEntTemperature::desc(),
        pRegionTemp);
    AcDbCircle::desc()->addX(AsdkEntTemperature::desc(),
        pCircleTemp);
    acedRegCmds->addCommand("ASDK_TEMPERATURE_APP",
        "ASDK_ENERGY", "ENERGY", ACRX_CMD_TRANSPARENT,
        energy);
void
unloadApp()
    delete acrxServiceDictionary->remove("AsdkTemperature");
    acedRegCmds->removeGroup("ASDK_TEMPERATURE_APP");
    // Remove protocol extension objects from the AcRxClass
    // object tree.  This must be done before removing the
    // AsdkEntTemperature class from the ACRX runtime class
    // hierarchy, so the AsdkEntTemperature::desc()
    // still exists.
    AcDbEntity::desc()->delX(AsdkEntTemperature::desc());
    delete pDefaultTemp;
    AcDbRegion::desc()->delX(AsdkEntTemperature::desc());
    delete pRegionTemp;
    AcDbCircle::desc()->delX(AsdkEntTemperature::desc());
    delete pCircleTemp;
    // Remove the AsdkEntTemperature class from the ARX
    // runtime class hierarchy.
    deleteAcRxClass(AsdkEntTemperature::desc());
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appId)
    switch (msg) {
    case AcRx::kInitAppMsg:
        acrxDynamicLinker->unlockApplication(appId);
        acrxDynamicLinker->registerAppMDIAware(appId);
        initApp();
        break;
    case AcRx::kUnloadAppMsg:
        unloadApp();
    return AcRx::kRetOK;
  1. 协议扩展
GMT+8, 2026-10-23 08:24
