AddFile 方法 (ActiveX/ATO)
将非图形文件添加到传递集。 支持的平台:仅限 Windows 命名空间:传输塔利布 程序集: acETransmit20.tlb 签名VB.NET: RetVal = object.addFile(bstrFullPath, pIParentFile, bAddedBy3rdParty, ppIAddedFile) C#: RetVal = object.addFile(bstrFullPath, pIParentFile, bAddedBy3rdParty, out ppIAddedFile);
言论没有其他评论。 发行信息释放:AutoCAD 2004 及更高版本 历史
例子VB.NET: ' Custom command to create a transmittal package with a non-drawing file
<CommandMethod("eTransmitNonDWGFile")> _
Public Shared Sub eTransmitNonDWGFile()
Dim ti As TransmittalInfo = _
TransInfo(tro.getTransmittalInfoInterface(), "C:\Users\Public\TransmittalAPITest\")
' Add a non-drawing file
Dim tf As TransmittalFile = Nothing
tro.addFile("C:\AutoCAD\Sample\Mechanical Sample\mass-balance.xls", Nothing, 0, tf)
' Create the transmittal package
' Files are copied and resaved to the path specified by the destinationRoot property
' and the other settings of the TransmittalInfo object.
tro.createTransmittalPackage()
C#: // Custom command to create a transmittal package with a non-drawing file
[CommandMethod("eTransmitNonDWGFile")]
public static void eTransmitNonDWGFile()
TransmittalInfo ti =
TransInfo(tro.getTransmittalInfoInterface(), "C:\\Users\\Public\\TransmittalAPITest\\");
// Add a non-drawing file
TransmittalFile tf = null;
tro.addFile("C:\\AutoCAD\\Sample\\Mechanical Sample\\mass-balance.xls", null, 0, out tf);
// Create the transmittal package
// Files are copied and resaved to the path specified by the destinationRoot property
// and the other settings of the TransmittalInfo object.
tro.createTransmittalPackage();
相关参考 |
GMT+8, 2026-10-23 08:45
