AddDrawingFile 方法 (ActiveX/ATO)
2024-5-18 18:59| 发布者: admin| 查看: 708| 评论: 0|原作者: admin|来自: AutoCAD
将图形文件添加到传递集。
命名空间:传输塔利布
程序集: acETransmit20.tlb
VBA/VB.NET:
RetVal = object.addDrawingFile(fullpathname, ppIAddedFile)
C#:
RetVal = object.addDrawingFile(fullpathname, out ppIAddedFile);
类型:TransmittalOperation 对象
此方法应用到的对象。
完整路径名
访问:仅输入
类型:字符串
要添加到传递集的图形文件的路径和名称。
ppIAdded文件
访问:仅输出
类型:TransmittalFile 对象
TransmittalFile对象,表示添加到传递集的图形文件。
返回值 (RetVal)
类型:AddFileReturnVal 枚举
表示图形文件是否已成功添加到传递集的常量值。
发行信息
释放:AutoCAD 2005 及更高版本
历史
  • 该界面已与 AutoCAD 2010 版库中的界面合并。ITransmittalOperation2ITransmittalOperation
  • 该方法是在 AutoCAD 2005 版本的库中引入的。addDrawingFileITransmittalOperation2
VB.NET:
' Custom command to create a transmittal package with a drawing file
<CommandMethod("eTransmitDWGFile")> _
Public Shared Sub eTransmitDWGFile()
    Dim ti As TransmittalInfo = _
        TransInfo(tro.getTransmittalInfoInterface(), "C:\Users\Public\TransmittalAPITest\")
    ' Add a DWG file
    Dim tf As TransmittalFile = Nothing
    tro.addDrawingFile("C:\AutoCAD\Sample\Sheet Sets\Architectural\A-02.dwg", tf)
    ' Reclaculate the sub path for all files in the transmittal package
    tro.recalcTargetSubPath()
    ' Create the transmittal package
    ' Files are copied and resaved to the path specified by the destinationRoot property
    ' and the other settings of the TransmittalInfo object.
    tro.createTransmittalPackage()
C#:
// Custom command to create a transmittal package with a drawing file
[CommandMethod("eTransmitDWGFile")]
public static void eTransmitDWGFile()
    TransmittalInfo ti =
        TransInfo(tro.getTransmittalInfoInterface(), "C:\\Users\\Public\\TransmittalAPITest\\");
    // Add a DWG file
    TransmittalFile tf = null;
    tro.addDrawingFile("C:\\AutoCAD\\Sample\\Sheet Sets\\Architectural\\A-02.dwg", out tf);
    // Reclaculate the sub path for all files in the transmittal package
    tro.recalcTargetSubPath();
    // Create the transmittal package
    // Files are copied and resaved to the path specified by the destinationRoot property
    // and the other settings of the TransmittalInfo object.
    tro.createTransmittalPackage();
GMT+8, 2026-10-23 09:38
