BadObjectName 属性 (ActiveX/CSP)
指定其属性与要比较的图形标准文件中定义的属性不匹配的对象的名称。 支持的平台:仅限 Windows 命名空间:AcStMgr (英语) 集会:AcStMgr.tlb 属性值只读:不 类型:字符串 与错误关联的对象的名称。 言论没有其他评论。 发行信息释放:AutoCAD 2004 及更高版本
例子VB.NET: Public Sub PlugIn_Next() _
Implements IAcStPlugin2.Next
m_pError = Nothing
If m_ContextList.Count > 0 Then
' Check to see if there are objects to check
' << Change based on standards implementation >>
If m_LayerCacheArray.Length() > 0 Then
Dim bFoundError As Boolean
' Check to see if this is the last object to be checked
If m_curIndex < m_ContextList.Count - 1 Then
m_curIndex = m_curIndex + 1
bFoundError = False
Dim layerObj As AcadLayer
Dim iCache As Integer
' Iterate the objects to be checked
While m_curIndex < m_ContextList.Count
' Get the ObjectId of the object to be checked
layerObj = m_pCheckDatabase.ObjectIdToObject(m_ContextList.Item(m_curIndex))
' Iterate through each of the standards objects and check for a match based on name
For iCache = LBound(m_LayerCacheArray) To UBound(m_LayerCacheArray)
' Compare the names of the two layers
If (layerObj.Name.CompareTo(m_LayerCacheArray(iCache).Name) <> 0) Then
' Check to see if the object is a macth,
' if not flag as possible error
bFoundError = True
Else
bFoundError = False
' Layer names matched, compare color and linetype values
If layerObj.color.ToString() <> m_LayerCacheArray(iCache).Color.ToString() Or _
layerObj.Lineweight.ToString() <> m_LayerCacheArray(iCache).Lineweight.ToString() Then
bFoundError = True
End If
' Exit For loop since a match by name was found
Exit For
End If
Next
' No match or a property difference was found
If bFoundError = True Then
Dim pError As New AcStError()
' Assign a description to the error
pError.Description = "Layer is non-standard"
' Assign an ObjectId to the error
pError.BadObjectId = layerObj.ObjectID
' Assign the name of the object, plug-in, and error type
pError.BadObjectName = layerObj.Name
pError.Plugin = m_pPlugin
pError.ErrorTypeName = "Layer "
' Assign a result status to the error
pError.ResultStatus = AcStResultStatus.acStResFlagsNone
' Assign the object's property values to the error for checking
If pError.PropertyCount = 0 Then
pError.PropertyValuePut("Color", layerObj.color)
pError.PropertyValuePut("Lineweight", layerObj.Lineweight)
End If
m_pError = pError
bFoundError = False
Exit While
End If
' Increment the counter
End While
End If
End If
End If
C#: public void PlugIn_Next()
m_pError = null;
if (m_ContextList.Count > 0)
AcadLayer layerObj = default(AcadLayer);
int iCache = 0;
bool bFoundError = false;
// Check to see if there are objects to check
// << Change based on standards implementation >>
if (m_LayerCacheArray.Length > 0)
// Check to see if this is the last object to be checked
if (m_curIndex < m_ContextList.Count - 1)
m_curIndex = m_curIndex + 1;
// Iterate the objects to be checked
while (m_curIndex < m_ContextList.Count)
// Get the ObjectId of the object to be checked
layerObj = (AXDBLib.AcadLayer)m_pCheckDatabase.ObjectIdToObject((long)m_ContextList.GetItem(m_curIndex));
int nLBound = m_LayerCacheArray.GetLowerBound(0);
int nUBound = m_LayerCacheArray.GetUpperBound(0);
// Iterate through each of the standards objects and check for a match based on name
for (iCache = nLBound; iCache <= nUBound; iCache++)
// Compare the names of the two layers
if ((layerObj.Name.CompareTo(m_LayerCacheArray[iCache].Name) != 0))
// Check to see if the object is a macth,
// if not flag as possible error
bFoundError = true;
else
// Layer names matched, compare color and linetype values
if (layerObj.color.ToString() != m_LayerCacheArray[iCache].Color.ToString() |
layerObj.Lineweight.ToString() != m_LayerCacheArray[iCache].Lineweight.ToString())
bFoundError = true;
// Exit For loop since a match by name was found
break;
// No match or a property difference was found
if (bFoundError == true)
AcStError pError = new AcStError();
// Assign a description to the error
pError.Description = "Layer is non-standard";
// Assign an ObjectId to the error
pError.BadObjectId = layerObj.ObjectID;
// Assign the name of the object, plug-in, and error type
pError.BadObjectName = layerObj.Name;
pError.Plugin = m_pPlugin;
pError.ErrorTypeName = "Layer ";
// Assign a result status to the error
pError.ResultStatus = AcStResultStatus.acStResFlagsNone;
// Assign the object's property values to the error for checking
if (pError.PropertyCount == 0)
pError.PropertyValuePut("Color", (ACAD_COLOR)layerObj.color);
pError.PropertyValuePut("Lineweight", (ACAD_LWEIGHT)layerObj.Lineweight);
m_pError = pError;
break;
// Increment the counter
GMT+8, 2026-10-24 20:48
