NewDrawing 事件 (ActiveX)
在创建新图形之前触发。 支持的平台:仅限 Windows 言论显示模式对话框时不会触发任何事件。 例子VBA: Public WithEvents ACADApp As AcadApplication ' Use with Application Event Examples
Sub Example_AcadApplication_Events()
' This example intializes the public variable (ACADApp) which will be used
' to intercept AcadApplication Events
' The VBA WithEvents statement makes it possible to intercept an generic object
' with the events associated with that object.
' Before you will be able to trigger any of the AcadApplication events,
' you will first need to run this procedure.
' We could get the application from the ThisDocument object, but that would
' require having a drawing open, so we grab it from the system.
Set ACADApp = GetObject(, "AutoCAD.Application.24.2")
Private Sub ACADApp_NewDrawing()
' This example intercepts an Application NewDrawing event.
' This event is triggered when a new drawing request is sent to AutoCAD.
' To trigger this example event:
' 1) Make sure to run the example that initializes
' the public variable (named ACADApp) linked to this event.
' 2) Use AutoCAD to create a new drawing using File/New
MsgBox "A request to start a new drawing was just intercepted!"
可视化 LISP: Not available |
GMT+8, 2026-10-23 04:49
