修改的事件 (ActiveX)
在修改图形中的对象或集合时触发。 支持的平台:仅限 Windows 签名VBA: object.Modified(Entity)
言论每当修改对象时,都会触发此事件。修改包括设置属性值的时间,即使新值等于当前值也是如此。 在 VBA 中编码时,必须为为该事件启用的所有对象提供事件处理程序。如果不提供处理程序,VBA 可能会意外终止。Modified 显示模式对话框时不会触发任何事件。 例子VBA: Public WithEvents PLine As AcadLWPolyline ' Use with Modified Event Example
Sub Example_Modified()
' This example creates a lightweight polyline in model space and
' references the PolyLine using the public variable (PLine) which
' is set up to intercept Modified events.
' This example then modifies the new object, triggering the code
' in the Modified event.
Dim points(0 To 9) As Double
' Define the 2D polyline points
points(0) = 1: points(1) = 1
points(2) = 1: points(3) = 2
points(4) = 2: points(5) = 2
points(6) = 3: points(7) = 2
points(8) = 4: points(9) = 4
' Create a lightweight Polyline object in model space
' * Note: We are returning the new PolyLine object into a Module
' level variable. This allows us to intercept events associated
' with that particular object.
Set PLine = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
' Modify object to trigger event.
' * Note: The event code for the PolyLine modification will be triggered
' before we move forward and refresh the view, so the line will not
' appear blue when the event message box is displayed.
Dim color As AcadAcCmColor
Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." + Left(AcadApplication.Version, 2))
Call color.SetRGB(80, 100, 244)
PLine.TrueColor = color
Private Sub PLine_Modified(ByVal pObject As AutoCAD.IAcadObject)
' This example intercepts an object's Modified event.
' This event is triggered when an object supporting this event is modified.
' To trigger this code: Modify an object connected to this event
' * Note: By connected, we mean the object set up to intercept events using
' the VBA WithEvents statement
' Use the "pObject" variable to determine which object was modified
MsgBox "You just modified an object with an ID of: " & pObject.ObjectID
可视化 LISP: Not available |
GMT+8, 2026-10-23 00:52
