UseLastPlotSettings 属性 (ActiveX)
2024-5-18 18:57| 发布者: admin| 查看: 624| 评论: 0|原作者: admin|来自: AutoCAD
应用上次成功打印的打印设置。
object.UseLastPlotSettings
类型:首选项输出
此属性应用于的对象。
只读:
类型:布尔
  • True:使用上次成功绘图的设置作为当前绘图设置。
  • False:不要将上次成功打印的设置用作当前打印设置。
Sub Example_UseLastPlotSettings()
    ' This example reads and modifies the UseLastPlotSettings
    ' preference value.
    ' When finished, this example resets the preference value back to
    ' it's original value.
    Dim ACADPref As AcadPreferencesOutput
    Dim originalValue As Boolean
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Output
    originalValue = ACADPref.UseLastPlotSettings
    MsgBox "The UseLastPlotSettings preference is set to: " & originalValue
    ' Modify the UseLastPlotSettings preference by toggling the value
    ACADPref.UseLastPlotSettings = Not ACADPref.UseLastPlotSettings
    MsgBox "The UseLastPlotSettings preference has been set to: " & ACADPref.UseLastPlotSettings
    ' Reset the preference back to it's original value
    ACADPref.UseLastPlotSettings = originalValue
    MsgBox "The UseLastPlotSettings preference was reset back to: " & originalValue
(defun c:Example_UseLastPlotSettings()
    ;; This example reads and modifies the UseLastPlotSettings
    ;; preference value.
    ;; When finished, this example resets the preference value back to
    ;; it's original value.
    (setq originalValue (vla-get-UseLastPlotSettings (vla-get-Output preferences)))
    (alert (strcat "The UseLastPlotSettings preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the UseLastPlotSettings preference by toggling the value
    (vla-put-UseLastPlotSettings (vla-get-Output preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The UseLastPlotSettings preference has been set to: " (if (= (vla-get-UseLastPlotSettings (vla-get-Output preferences)) :vlax-true) "True" "False")))
    ;; Reset the preference back to it's original value
    (vla-put-UseLastPlotSettings (vla-get-Output preferences) originalValue)
    (alert (strcat "The UseLastPlotSettings preference was reset back to: " (if (= (vla-get-UseLastPlotSettings (vla-get-Output preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-9-17 14:32
