TextPrefix 属性 (ActiveX)
指定维度值前缀。 支持的平台:仅限 Windows 签名VBA: object.TextPrefix 属性值只读:不 类型:字符串 维度值的前缀。 言论此属性的初始值为“”。 注意:此属性将覆盖给定维度的 DIMPOST 系统变量的值。
例子VBA: Sub Example_TextPrefix()
' uses TextPrefix to allow the user to change the text prefix for the
' dimension
Dim dimObj As AcadDimAligned
Dim prefix As String
' Define the dimension
point1(0) = 0: point1(1) = 5: point1(2) = 0
point2(0) = 5: point2(1) = 5: point2(2) = 0
' Allow the user to change the text prefix for the dimension
prefix = InputBox("Enter a new text prefix for the dimension", "Set Dimension Prefix", "PREFIX:")
dimObj.TextPrefix = prefix ' Commit changes to prefix
' Read back and display the dimension text prefix
prefix = dimObj.TextPrefix
If prefix <> "" Then
MsgBox "The prefix of the dimension has been changed to: " & prefix
Else
MsgBox "The prefix of the dimension has been removed"
End If
可视化 LISP: (vl-load-com)
(defun c:Example_TextPrefix()
;; uses TextPrefix to allow the user to change the text prefix for the
;; dimension
;; Define the dimension
(setq point1 (vlax-3d-point 0 5 0)
point2 (vlax-3d-point 5 5 0)
(vla-ZoomAll acadObj)
;; Allow the user to change the text prefix for the dimension
(setq prefix (vla-GetString (vla-get-Utility doc) :vlax-false "\nEnter a new text prefix for the dimension: "))
(vla-put-TextPrefix dimObj prefix) ;; Commit changes to prefix
;; Read back and display the dimension text prefix
(setq prefix (vla-get-TextPrefix dimObj))
(if (/= prefix "")
(alert (strcat "The prefix of the dimension has been changed to: " prefix))
(alert "The prefix of the dimension has been removed")
GMT+8, 2026-10-24 09:47
