TextHeight 属性 (ActiveX)
指定尺寸或公差文本的高度。 支持的平台:仅限 Windows 签名VBA: object.TextHeight 属性值只读:不 类型:双 尺寸文本的高度。 言论此属性的初始值为 0.1800。 如果当前文本样式具有固定的文本高度,则忽略此属性。 注意:此属性将覆盖给定维度的 DIMTXT 系统变量的值。
例子VBA: Sub Example_TextHeight()
' uses the TextHeight property to increase the height of the
' dimension text
Dim dimObj As AcadDimAligned
' Define the dimension
point2(0) = 5.5: point2(1) = 5: point2(2) = 0
' Read and display current dimension text height
MsgBox "The dimension text height for this object is currently set to: " & dimObj.textHeight
' Increase the distance of the dimension gap
dimObj.TextHeight = 1
MsgBox "The dimension text height for this object is now set to: " & dimObj.textHeight
可视化 LISP: (vl-load-com)
(defun c:Example_TextHeight()
;; uses the TextHeight property to increase the height of the
;; dimension text
;; Define the dimension
point2 (vlax-3d-point 5.5 5 0)
(vla-ZoomAll acadObj)
;; Read and display current dimension text height
(alert (strcat "The dimension text height for this object is currently set to: " (rtos (vla-get-TextHeight dimObj) 2)))
;; Increase the distance of the dimension gap
(vla-put-TextHeight dimObj 1)
(alert (strcat "The dimension text height for this object is now set to: " (rtos (vla-get-TextHeight dimObj) 2)))
GMT+8, 2026-10-24 09:48
