TextFrameDisplay 属性 (ActiveX)
2024-5-18 18:57| 发布者: admin| 查看: 621| 评论: 0|原作者: admin|来自: AutoCAD
使用文本框或文本对象切换多引线文本内容周围的框架显示,而不是显示文本本身。
object.TextFrameDisplay
类型:DatabasePreferencesGeoPositionMarkerMLeader
此属性应用于的对象。
属性值 - DatabasePreferences
只读:
类型:布尔
  • True:显示文本范围周围的框架,但不显示文本本身。
  • False:显示全文。
属性值 - GeoPositionMarker、MLeader
只读:
类型:布尔
  • True:显示帧
  • False:不显示帧
此属性的初始值为 False。
DatabasePreferences:启用或禁用此选项后,必须使用该方法更新显示。Regen
注意:对象的此属性值存储在 QTEXTMODE 系统变量中。DatabasePreferences
Sub Example_TextFrameDisplay()
    ' TextFrameDisplay. It then changes the value, and finally
    Dim currTextFrameDisplay As Boolean
    ' Retrieve the current TextFrameDisplay value
    currTextFrameDisplay = ThisDrawing.Preferences.TextFrameDisplay
    MsgBox "The current value for TextFrameDisplay is " & Preferences.TextFrameDisplay, vbInformation, "TextFrameDisplay Example"
    ' Change the value for TextFrameDisplay
    ThisDrawing.Preferences.TextFrameDisplay = Not (currTextFrameDisplay)
    MsgBox "The new value for TextFrameDisplay is " & Preferences.TextFrameDisplay, vbInformation, "TextFrameDisplay Example"
    ' Reset TextFrameDisplay to its original value
    ThisDrawing.Preferences.TextFrameDisplay = currTextFrameDisplay
    MsgBox "The TextFrameDisplay value is reset to " & Preferences.TextFrameDisplay, vbInformation, "TextFrameDisplay Example"
(defun c:Example_TextFrameDisplay()
    ;; TextFrameDisplay. It then changes the value, and finally
    (setq preferences (vla-get-Preferences doc))
    ;; Retrieve the current TextFrameDisplay value
    (setq currTextFrameDisplay (vla-get-TextFrameDisplay preferences))
    (alert (strcat "The current value for TextFrameDisplay is " (if (= currTextFrameDisplay :vlax-true) "True" "False")))
    ;; Change the value for TextFrameDisplay
    (vla-put-TextFrameDisplay preferences (if (= currTextFrameDisplay :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The new value for TextFrameDisplay is " (if (= (vla-get-TextFrameDisplay preferences) :vlax-true) "True" "False")))
    ;; Reset TextFrameDisplay to its original value
    (vla-put-TextFrameDisplay preferences currTextFrameDisplay)
    (alert (strcat "The TextFrameDisplay value is reset to " (if (= (vla-get-TextFrameDisplay preferences) :vlax-true) "True" "False")))
GMT+8, 2026-9-7 14:37
