Perimeter 属性 (ActiveX)
2024-5-18 18:57| 发布者: admin| 查看: 872| 评论: 0|原作者: admin|来自: AutoCAD
获取内部和外部区域循环的总长度。
object.Perimeter
类型: 区域
此属性应用于的对象。
只读:是的
类型:
周长以绘图单位返回。
Sub Example_Perimeter()
    ' This example creates a region from an arc and a line.
    ' It then returns the length of the perimeter of the region.
    Dim curves(0 To 1) As AcadEntity
    Dim arcObj As AcadArc
    Dim lineObj As AcadLine
    ' Create the arc and line
    Dim radius As Double
    Dim startAngle As Double
    Dim endAngle As Double
    centerPoint(0) = 5#: centerPoint(1) = 3#: centerPoint(2) = 0#
    radius = 2#
    startAngle = 0
    endAngle = 3.141592
    Set arcObj = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngle, endAngle)
    Set lineObj = ThisDrawing.ModelSpace.AddLine(arcObj.startPoint, arcObj.endPoint)
    Set curves(0) = arcObj
    Set curves(1) = lineObj
    ' Create the region
    Dim regionObj As Variant
    regionObj = ThisDrawing.ModelSpace.AddRegion(curves)
    ZoomAll
    ' Find the perimeter of the region.
    Dim perimeter As Double
    perimeter = regionObj(0).perimeter
    MsgBox "The perimeter of the region is " & regionObj(0).perimeter, , "Perimeter Example"
(defun c:Example_Perimeter()
    ;; This example creates a region from an arc and a line.
    ;; It then returns the length of the perimeter of the region.
    ;; Create the arc and line
    (setq centerPoint (vlax-3d-point 5 3 0)
          radius 2
          startAngle 0
          endAngle 3.141592)
    (setq arcObj (vla-AddArc modelSpace centerPoint radius startAngle endAngle))
    (setq lineObj (vla-AddLine modelSpace (vla-get-StartPoint arcObj) (vla-get-EndPoint arcObj)))
    (setq curves (vlax-make-safearray vlax-vbObject '(0 . 1)))
    (vlax-safearray-put-element curves 0 arcObj)
    (vlax-safearray-put-element curves 1 lineObj)
    ;; Create the region
    (setq regionObj (vla-AddRegion modelSpace curves))
    (vla-ZoomAll acadObj)
    ;; Find the perimeter of the region.
    (setq perimeter (vla-get-Perimeter (vlax-safearray-get-element (vlax-variant-value regionObj) 0)))
    (alert (strcat "The perimeter of the region is " (rtos perimeter 2)))
GMT+8, 2026-9-10 15:48
