LeaderLength 属性 (ActiveX)
2024-5-18 18:57| 发布者: admin| 查看: 674| 评论: 0|原作者: admin|来自: AutoCAD
指定引线在直径或半径尺寸上的长度。
object.LeaderLength
类型:DimDiametric、DimRadial
此属性应用于的对象。
只读:不
类型:双
领导者的长度。
是从尺寸定义指向的距离,到尺寸将对注释文本进行水平狗腿的距离(如果不需要狗腿,则停止)。(有关详细信息,请参阅 or 方法。LeaderLengthChordPointAddDimDiametricAddDimRadial
注意:该设置将仅在创建维度期间使用。保存尺寸后,更改值不会影响尺寸的显示方式。该属性用于计算引线位置。该值不会保存,因此在读取时将始终返回零。LeaderLengthLeaderLengthLeaderLength
Sub Example_LeaderLength()
    ' This example creates a diametric dimension
    ' and returns the LeaderLength for that dimension.
    Dim dimObj As AcadDimDiametric
    Dim chordPoint(0 To 2) As Double
    Dim farChordPoint(0 To 2) As Double
    Dim leaderLength As Double
    ' Define the dimension
    chordPoint(0) = 5#: chordPoint(1) = 3#: chordPoint(2) = 0#
    farChordPoint(0) = 5#: farChordPoint(1) = 5#: farChordPoint(2) = 0#
    leaderLength = 1#
    ' Create the diametric dimension in model space
    Set dimObj = ThisDrawing.ModelSpace.AddDimDiametric(chordPoint, farChordPoint, leaderLength)
    ZoomAll
(defun c:Example_LeaderLength()
    ;; This example creates a diametric dimension
    ;; and returns the LeaderLength for that dimension.
    ;; Define the dimension
    (setq chordPoint (vlax-3d-point 5 3 0)
          farChordPoint (vlax-3d-point 5 5 0)
          leaderLength 1)
    ;; Create the diametric dimension in model space
    (setq dimObj (vla-AddDimDiametric modelSpace chordPoint farChordPoint leaderLength))
    (vla-ZoomAll acadObj)
GMT+8, 2026-11-1 19:32
