HasAttributes 属性 (ActiveX)
2024-5-18 18:57| 发布者: admin| 查看: 706| 评论: 0|原作者: admin|来自: AutoCAD
指定块中是否有任何属性。
object.HasAttributes
类型:BlockReferences、ComparedReference、ExternalReference、MInsertBlock
此属性应用于的对象。
只读:是的
类型:布尔
  • True:块引用具有属性。
  • False:块引用没有属性。
如果块引用包含任何可编辑或常量(不可编辑)属性,则此属性为。如果没有属性。TrueFalse
若要返回与块关联的对象数组,请使用该方法。AttributeGetAttributes
Sub Example_HasAttributes()
    ' This example first creates a block without attributes.
    ' It then inserts the block and checks whether it has attributes.
    ' It then adds attributes to the block and inserts it again.
    ' Then it checks the new block reference for attributes.
    ' Create the block
    Dim blockObj As AcadBlock
    Dim insertionPnt(0 To 2) As Double
    insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
    Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "CircleBlock")
    ' Add a circle to the block
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 0: center(1) = 0: center(2) = 0
    radius = 1
    Set circleObj = blockObj.AddCircle(center, radius)
    ' Insert the block
    Dim blockRefObj As AcadBlockReference
    insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1#, 1#, 1#, 0)
    MsgBox "This block reference " & IIf(blockRefObj.HasAttributes, "has attributes.", "does not have attributes."), , "Has Attributes Example"
    ' Add attributes to the block definition.
    ' Define the attribute definition.
    Dim attributeObj As AcadAttribute
    Dim height As Double
    Dim mode As Long
    Dim prompt As String
    Dim tag As String
    Dim value As String
    height = 1#
    mode = acAttributeModeVerify
    prompt = "Attribute Prompt"
    insertionPoint(0) = 1#: insertionPoint(1) = 1#: insertionPoint(2) = 0
    tag = "Attribute_Tag"
    value = "Attribute Value"
    ' Create the attribute definition
    Set attributeObj = blockObj.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
    ' Insert the block again
    Dim blockRefObj2 As AcadBlockReference
    insertionPnt(0) = 3#: insertionPnt(1) = 3#: insertionPnt(2) = 0
    Set blockRefObj2 = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1#, 1#, 1#, 0)
    ZoomAll
    MsgBox "The first block reference " & IIf(blockRefObj.HasAttributes, "has attributes.", "does not have attributes.") & vbCrLf & _
            "The second block reference " & IIf(blockRefObj2.HasAttributes, "has attributes.", "does not have attributes."), , "Has Attributes Example"
(defun c:Example_HasAttributes()
    ;; This example first creates a block without attributes.
    ;; It then inserts the block and checks whether it has attributes.
    ;; It then adds attributes to the block and inserts it again.
    ;; Then it checks the new block reference for attributes.
    ;; Create the block
    (setq insertionPnt (vlax-3d-point 0 0 0))
    (setq blockObj (vla-Add (vla-get-Blocks doc) insertionPnt "CircleBlock"))
    ;; Add a circle to the block
    (setq center (vlax-3d-point 0 0 0))
    (setq radius 1)
    (setq circleObj (vla-AddCircle blockObj center radius))
    ;; Insert the block
    (setq insertionPnt (vlax-3d-point 2 2 0))
    (setq blockRefObj (vla-InsertBlock modelSpace insertionPnt "CircleBlock" 1 1 1 0))
    (vla-ZoomAll acadObj)
    (alert (strcat "This block reference " (if (= (vla-get-HasAttributes blockRefObj) :vlax-true) "has attributes." "does not have attributes.")))
    ;; Add attributes to the block definition.
    ;; Define the attribute definition.
    (setq insertionPoint (vlax-3d-point 1 1 0)
          attHeight 1
          attMode acAttributeModeVerify
          attPrompt "Attribute Prompt"
          attTag "Attribute_Tag"
          attValue "Attribute Value")
    ;; Create the attribute definition
    (setq attributeObj (vla-AddAttribute blockObj attHeight attMode attPrompt insertionPoint attTag attValue))
    ;; Insert the block again
    (setq insertionPnt (vlax-3d-point 3 3 0))
    (setq blockRefObj2 (vla-InsertBlock modelSpace insertionPnt "CircleBlock" 1 1 1 0))
    (alert (strcat "The first block reference " (if (= (vla-get-HasAttributes blockRefObj) :vlax-true) "has attributes." "does not have attributes.")
                   "\nThe second block reference " (if (= (vla-get-HasAttributes blockRefObj2) :vlax-true) "has attributes." "does not have attributes.")))
GMT+8, 2026-10-23 00:15
