Fade 属性 (ActiveX)
指定光栅或参考底图图像的当前淡入淡出值。 支持的平台:仅限 Windows 签名VBA: object.Fade
属性值只读:不 类型:长 该值介于 0 和 100 之间(含 0 和 100)。 言论您可以调整光栅或参考底图图像的亮度、对比度和淡入淡出,以显示图像以及打印输出,而不会影响原始光栅或参考底图文件。调整亮度以使图像变暗或变亮。调整对比度,使质量较差的图像更易于阅读。调整淡入淡出使矢量在图像上更易于查看,并在绘制的输出中创建水印效果。 注意:无法调整双色调图像的亮度、对比度或淡入淡出。
例子VBA: Sub Example_Fade()
' This example inserts a raster image and finds the current
' Fade value of the image. It then changes the Fade value
' of the image.
' This example uses the "2d Projected Polylines.jpg" found in the Sample
' directory. If you do not have the image, or if it is located
' in a different directory, insert a valid path and name for the
' imageName variable below.
Dim scalefactor As Double
Dim rotAngleInDegree As Double
Dim rotAngle As Double
Dim imageName As String
Dim raster As AcadRasterImage
imageName = "C:\AutoCAD\sample\2d Projected Polylines.jpg"
insertionPoint(0) = 2#: insertionPoint(1) = 2#: insertionPoint(2) = 0#
scalefactor = 1#
rotAngleInDegree = 0#
rotAngle = rotAngleInDegree * 3.141592 / 180#
On Error Resume Next
' Creates a raster image in model space
Set raster = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotAngle)
If Err.Description = "Filer error" Then
MsgBox imageName & " could not be found."
Exit Sub
End If
' Find the current Fade
ThisDrawing.Regen True
MsgBox "The Fade is currently set to: " & raster.Fade, vbInformation
' Change the Fade to 5
raster.Fade = 50
MsgBox "The Fade is now set to: " & raster.Fade, vbInformation
可视化 LISP: (vl-load-com)
(defun c:Example_Fade()
;; This example inserts a raster image and finds the current
;; Fade value of the image. It then changes the Fade value
;; of the image.
;; This example uses the "2d Projected Polylines.jpg" found in the Sample
;; directory. If you do not have the image, or if it is located
;; in a different directory, insert a valid path and name for the
;; imageName variable below.
(setq insertionPoint (vlax-3d-point 2 2 0)
imageName ".\\Sample\\VBA\\2d Projected Polylines.jpg"
scalefactor 1
rotAngle (/ (* 0 3.141592) 180))
(if (/= (findfile imageName) nil)
(progn
;; Creates a raster image in model space
(setq raster (vla-AddRaster modelSpace (findfile imageName) insertionPoint scalefactor rotAngle))
(vla-ZoomExtents acadObj)
;; Find the current Fade
(vla-Regen doc :vlax-true)
(alert (strcat "The Fade is currently set to: " (rtos (vla-get-Fade raster) 2)))
;; Change the Fade to 5
(vla-put-Fade raster 5)
(alert (strcat "The Fade is now set to: " (rtos (vla-get-Fade raster) 2)))
(alert (strcat imageName " could not be found."))
GMT+8, 2026-10-23 00:25
