DriversPath 属性 (ActiveX)
2024-5-18 18:56| 发布者: admin| 查看: 1042| 评论: 0|原作者: admin|来自: AutoCAD
指定AutoCAD在其中查找视频显示、指点设备、打印机和绘图仪的ADI设备驱动程序的目录。
object.DriversPath
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
设备驱动程序所在的目录。为每个路径指定驱动器号和路径。用分号 (;).
Sub Example_DriversPath()
    ' DriversPath. It then changes the value, and finally
    Dim currDriversPath As String
    Dim newDriversPath As String
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current DriversPath value
    currDriversPath = preferences.Files.DriversPath
    MsgBox "The current value for DriversPath is " & currDriversPath, vbInformation, "DriversPath Example"
    ' Change the value for DriversPath
    newDriversPath = "TestDriversPath"
    preferences.Files.DriversPath = newDriversPath
    MsgBox "The new value for DriversPath is " & newDriversPath, vbInformation, "DriversPath Example"
    ' Reset DriversPath to its original value
    preferences.Files.DriversPath = currDriversPath
    MsgBox "The DriversPath value is reset to " & currDriversPath, vbInformation, "DriversPath Example"
(defun c:Example_DriversPath()
    ;; DriversPath. It then changes the value, and finally
    ;; Retrieve the current DriversPath value
    (setq currDriversPath (vla-get-DriversPath (vla-get-Files preferences)))
    (alert (strcat "The current value for DriversPath is " currDriversPath))
    ;; Change the value for DriversPath
    (setq newDriversPath "TestDriversPath")
    (vla-put-DriversPath (vla-get-Files preferences) newDriversPath)
    (alert (strcat "The new value for DriversPath is " newDriversPath))
    ;; Reset DriversPath to its original value
    (vla-put-DriversPath (vla-get-Files preferences) currDriversPath)
    (alert (strcat "The DriversPath value is reset to " currDriversPath))
GMT+8, 2026-11-18 03:32
