ArcSmoothness 属性 (ActiveX)
指定圆、圆弧和椭圆的平滑度。 支持的平台:仅限 Windows 属性值只读:不 类型:整数 从 1 到 20,000 的正整数。 言论此属性的初始值为 100。 数字越大,对象越平滑,但 AutoCAD 需要更多时间来重新生成它们。可以通过将此属性设置为较低的绘图值和增加渲染值来提高性能。有效范围为 1 到 20,000。 例子VBA: Sub Example_ArcSmoothness()
' ArcSmoothness. It then changes the value, and finally
Dim currArcSmoothness As Integer
Dim newArcSmoothness As Integer
' Retrieve the current ArcSmoothness value
currArcSmoothness = ThisDrawing.ActiveViewport.ArcSmoothness
MsgBox "The current value for ArcSmoothness is " & currArcSmoothness, vbInformation, "ArcSmoothness Example"
' Change the value for ArcSmoothness
newArcSmoothness = 2001
ThisDrawing.ActiveViewport.ArcSmoothness = newArcSmoothness
MsgBox "The new value for ArcSmoothness is " & newArcSmoothness, vbInformation, "ArcSmoothness Example"
' Reset ArcSmoothness to its original value
ThisDrawing.ActiveViewport.ArcSmoothness = currArcSmoothness
MsgBox "The ArcSmoothness value is reset to " & currArcSmoothness, vbInformation, "ArcSmoothness Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ArcSmoothness()
;; ArcSmoothness. It then changes the value, and finally
;; Retrieve the current ArcSmoothness value
(setq currArcSmoothness (vla-get-ArcSmoothness (vla-get-ActiveViewport doc)))
(alert (strcat "The current value for ArcSmoothness is " (itoa currArcSmoothness)))
;; Change the value for ArcSmoothness
(setq newArcSmoothness 2001)
(vla-put-ArcSmoothness (vla-get-ActiveViewport doc) newArcSmoothness)
(alert (strcat "The new value for ArcSmoothness is " (itoa newArcSmoothness)))
;; Reset ArcSmoothness to its original value
(vla-put-ArcSmoothness (vla-get-ActiveViewport doc) currArcSmoothness)
(alert (strcat "The ArcSmoothness value is reset to " (itoa currArcSmoothness)))
GMT+8, 2026-10-23 00:15
