Active 属性 (ActiveX)
2024-5-18 18:56| 发布者: admin| 查看: 610| 评论: 0|原作者: admin|来自: AutoCAD
Active 属性 (ActiveX)
确定文档是否为会话的活动文档。
object.Active
类别: 文档
此属性应用于的对象。
只读:是的
类型:布尔
确定文档是否为会话的活动文档。
  • True:文档是活动文档。
  • False:文档不是活动文档。
Sub Example_Active()
    ' This example creates two new drawings and determines
    ' which of the drawings is the active drawing.
    Dim NewDrawing1 As AcadDocument
    Dim Newdrawing2 As AcadDocument
    Set NewDrawing1 = ThisDrawing.Application.Documents.Add("")
    Set Newdrawing2 = ThisDrawing.Application.Documents.Add("")
    Dim activeStatus As String
    Dim drawing As AcadDocument
    activeStatus = ""
    For Each drawing In ThisDrawing.Application.Documents
        If drawing.Active Then
                activeStatus = activeStatus & drawing.Name & " is active." & vbCrLf
        Else
                activeStatus = activeStatus & drawing.Name & " is not active." & vbCrLf
        End If
    Next drawing
    MsgBox activeStatus
(defun c:Example_Active()
    ;; This example creates two new drawings and determines
    ;; which open drawing is the active drawing.
    (setq docs (vla-get-Documents acadObj))
    (setq NewDrawing1 (vla-Add docs ""))
    (setq NewDrawing2 (vla-Add docs ""))
    (setq activeStatus "")
    (vlax-for each-doc docs
      (princ (vla-get-Active each-doc))
        (if (= (vla-get-Active each-doc) :vlax-true)
           (setq activeStatus (strcat activeStatus (vla-get-name each-doc) " is active.\n"))
           (setq activeStatus (strcat activeStatus (vla-get-name each-doc) " is not active.\n"))
    (alert activeStatus)
GMT+8, 2026-11-2 15:03
