GetAllProfileNames 方法 (ActiveX)
2024-5-18 18:55| 发布者: admin| 查看: 584| 评论: 0|原作者: admin|来自: AutoCAD
获取系统的所有可用配置文件。
object.GetAllProfileNames pNames
类型:PreferencesProfiles
此方法应用到的对象。
p名称
访问:仅输出
类型:变体(字符串数组)
系统的可用配置文件名称的数组。
返回值 (RetVal)
无返回值。
Sub Example_GetAllProfileNames()
    ' This example gets all the profiles available for the system.
    Dim systemProfiles As Variant
    AcadApplication.Preferences.Profiles.GetAllProfileNames systemProfiles
    ' List all the profiles for the system
    Dim x As Integer
    Dim msg As String
    msg = ""
    For x = LBound(systemProfiles) To UBound(systemProfiles)
        msg = msg & systemProfiles(x) & vbCrLf
    Next
    MsgBox msg, vbInformation, "Available Profiles"
(defun c:Example_GetAllProfileNames()
    ;; This example gets all the profiles available for the system.
    ;; Use the PreferencesProfiles object
    (setq systemProfiles "")
    (vla-GetAllProfileNames (vla-get-Profiles preferences) 'systemProfiles)
    ;; List all the profiles for the system
    (setq x 0
          msg "")
    (while (>= (vlax-safearray-get-u-bound systemProfiles 1) x)
        (setq msg (strcat msg (vlax-safearray-get-element systemProfiles x) "\n"))
        (setq x (1+ x))
    (alert msg)
GMT+8, 2026-11-1 19:32
