ComparedReference 对象 (ActiveX)
2024-5-18 18:55| 发布者: admin| 查看: 1030| 评论: 0|原作者: admin|来自: AutoCAD
表示要与当前图形进行比较的图形的外部参照。
班级信息
类名
AcadComparedReference
对象继承
Object
   AcadObject
      AcadEntity
         AcadBlockReference
            AcadExternalReference
创建方式
VBA的
Not applicable
通过访问方式
VBA的
ModelSpace.Item
该对象从该对象继承其成员。可以使用 ActiveX 查询和编辑 AutoCAD 图形中的图元。但是,您不能使用 ActiveX 创建对象。ComparedReferenceExternalReferenceComparedReferenceComparedReference
没有允许您将对象标识为该类型的成员属性;但是,您可以将 OR 强制转换为对象类型,并使用错误处理来确定强制转换是否成功。ExternalReferenceComparedReferenceAcadEntityAcadExternalReferenceAcadComparedReference
以下代码示例演示如何使用强制转换类型来确定实体是否为 类型。ComparedReference
' Checks to see if an object is of the ComparedReference type
Sub CheckForComparedReference()
  Dim ent As AcadEntity
  Dim comRef As AcadComparedReference
  On Error Resume Next
  ' Step through all the objects in model space
  For Each ent In ThisDrawing.ModelSpace
    ' Check to see if the object is a Block Reference
    If ent.ObjectName = "AcDbBlockReference" Then
      ' Try to cast the entity (Block Reference) to a ComparedReference
      Set comRef = ent
      ' If an occurs, then the entity is not a ComparedReference
      If Err <> 0 Then
        MsgBox "Not a Compared Reference"
      Else
        MsgBox "Xref Name: " + comRef.Name + vbLf + "Compared Reference"
      End If
      ' Clear the Error object
      Err.Clear
    End If
  Next ent
(defun c:CheckForComparedReference()
  ;; Checks to see if an object is of the ComparedReference type
  ;; Step through all the objects in model space
  (vlax-for obj (vla-get-ModelSpace doc)
    ;; Check to see if the object is a Block Reference
    (if (= (vla-get-objectname obj) "AcDbBlockReference")
      (progn
        ;; Transform the VLA-OBJECT to an ENAME
        (setq entName (vlax-vla-object->ename obj))
        ;; Check to see what the value of the IsComparedReference property is of the entity
        (if (vl-catch-all-error-p (vl-catch-all-apply 'getpropertyvalue (list entName "IsComparedReference")))
          ;; If an error occurs, then the entity is not a ComparedReference
          (alert "Not a Compared Reference")
          (alert (strcat "Xref Name: "
                         (vla-get-name obj)
                         "\nCompared Reference"))
GMT+8, 2026-10-23 01:04
