关于启用对象级事件 (VBA/ActiveX)
2024-5-18 18:55| 发布者: admin| 查看: 694| 评论: 0|原作者: admin|来自: AutoCAD
在使用对象级事件之前,必须创建一个新的类模块,并使用事件声明一个类型的对象。AcadObject
例如,假定创建了一个新的类模块并命名为 EventClassModule。新的类模块包含使用 VBA 关键字的应用程序声明。WithEvents
每当折线更新时,显示闭合折线的面积
此示例创建包含事件的轻量级折线。然后,每当折线发生更改时,折线的事件处理程序都会显示新区域。要触发事件,只需在AutoCAD中更改折线的大小即可。请记住,在激活事件处理程序之前,必须运行子例程。CreatePLineWithEvents
Public WithEvents PLine As AcadLWPolyline
Sub CreatePLineWithEvents()
 ' This example creates a light weight polyline
 Dim points(0 To 9) As Double
 points(0) = 1: points(1) = 1
 points(2) = 1: points(3) = 2
 points(4) = 2: points(5) = 2
 points(6) = 3: points(7) = 3
 points(8) = 3: points(9) = 2
 Set PLine = ThisDrawing.ModelSpace. _
 AddLightWeightPolyline(points)
 PLine.Closed = True
Private Sub PLine_Modified _
 (ByVal pObject As AutoCAD.IAcadObject)
 ' This event is triggered when the polyline is resized.
 ' If the polyline is deleted the modified event is still
 ' triggered, so we use the error handler to avoid
 ' reading data from a deleted object.
 On Error GoTo ERRORHANDLER
 MsgBox "The area of " & pObject.ObjectName & " is: " _
 & pObject.Area
 Exit Sub
ERRORHANDLER:
 MsgBox Err.Description
GMT+8, 2026-10-23 04:10
