AutoCAD 2004 API 历史记录参考 (ActiveX)
2024-5-18 18:54| 发布者: admin| 查看: 1004| 评论: 0|原作者: admin|来自: AutoCAD
对 AutoCAD 2004 和基于 AutoCAD 2004 的产品中的 ActiveX API 所做的添加和更改。
枚举
AcViewportScale (Change)
        acVp1and1_2in_1ft = 30 (Changed)
        acVp3in_1ft = 31 (Changed)
        acVp6in_1ft = 32 (Changed)
        acVp1ft_1ft = 33 (New)
AcSaveAsType (Changed)
        ac2000_dwg = 12 (New)
        ac2000_dxf = 13 (New)
        ac2000_Template = 14 (New)
        ac2004_dwg = 24 (New)
        ac2004_dxf = 25 (New)
        ac2004_Template = 26 (New)
        acNative = 24 (Changed)
        acR18_dwg = 24 (New)
        acR18_dxf = 25 (New)
        acR18_Template = 26 (New)
AcShadePlot (New)
        acShadePlotAsDisplayed = 0
        acShadePlotWireframe = 1
        acShadePlotHidden = 2
        acShadePlotRendered = 3
AcHatchObjectType (New)
        acHatchObject = 0
        acGradientObject = 1
AcGradientPatternType (New)
        acPreDefinedGradient = 0
        acUserDefinedGradient = 1
AcColorMethod (New)
        acColorMethodByLayer = 192
        acColorMethodByBlock = 193
        acColorMethodByRGB = 194
        acColorMethodByACI = 195
        acColorMethodForeground = 197
AcadSecurityParamsType (New)
        ACADSECURITYPARAMS_ENCRYPT_DATA = 1
        ACADSECURITYPARAMS_ENCRYPT_PROPS = 2
        ACADSECURITYPARAMS_SIGN_DATA = 16
        ACADSECURITYPARAMS_ADD_TIMESTAMP = 32
AcadSecurityParamsConstants (New)
        ACADSECURITYPARAMS_ALGID_RC4 = 26625
类
IAcadDatabase (Changed)
        FileDependencies - Property (New)
        SummaryInfo - Property (New)
IAcadBlock (Changed)
        InsertBlock - Method (Changed - Password parameter)
        AddHatch - Method (Changed - Hatch object type parameter)
        AddMInsertBlock - Method (Changed - Password parameter)
        AttachExternalReference - Method (Changed - Password parameter)
IAcadEntity (Changed)
        TrueColor - Property (New)
IAcadAcCmColor (New)
        EntityColor - Property
        ColorName - Property
        BookName - Property
        SetNames - Method
        Delete - Method
        Red - Property
        Blue - Property
        Green - Property
        SetRGB - Method
        ColorMethod - Property
        ColorIndex - Property
        SetColorBookColor - Method
IAcad3DPolyline (Changed)
        Length - Property (New)
IAcadDimension (Changed)
        TextColor - Property (New)
IAcadMText (Changed)
        LineSpacingDistance - Property (New)
IAcadLWPolyline (Changed)
IAcadPolyline (Changed)
IAcadTolerance (Changed)
IAcadHatch (Changed)
        GradientColor1 - Property (New)
        GradientColor2 - Property (New)
        GradientAngle - Property (New)
        GradientCentered - Property (New)
        GradientName - Property (New)
        HatchObjectType - Property (New)
IAcadPViewport (Changed)
        RemoveHiddenLines - Property (Hidden)
        ShadePlot - Property (New)
IAcadGroup (Changed)
        color - Property (Hidden)
IAcadLayer
IAcadFileDependencies (New)
        Item - Method
        Application - Property
        Count - Property
        CreateEntry - Method
        IndexOf - Method
        RemoveEntry - Method
        UpdateEntry - Method
IAcadFileDependency (New)
        FullFileName - Property
        FileName - Property
        FoundPath - Property
        FingerprintGuid - Property
        VersionGuid - Property
        Feature - Property
        IsModified - Property
        AffectsGraphics - Property
        Index - Property
        TimeStamp - Property
        FileSize - Property
        ReferenceCount - Property
IAcadSummaryInfo (New)
        Author - Property
        Comments - Property
        HyperlinkBase - Property
        Keywords - Property
        LastSavedBy - Property
        RevisionNumber - Property
        Subject - Property
        Title - Property
        NumCustomInfo - Method
        GetCustomByIndex - Method
        GetCustomByKey - Method
        SetCustomByIndex - Method
        SetCustomByKey - Method
        AddCustomInfo - Method
        RemoveCustomByIndex - Method
        RemoveCustomByKey - Method
IAcadSecurityParams (New)
        Action - Property
        Password - Property
        ProviderType - Property
        ProviderName - Property
        Algorithm - Property
        KeyLength - Property
        Subject - Property
        Issuer - Property
        SerialNumber - Property
        Comment - Property
        TimeServer - Property
IAcadDocument (Changed)
        Open - Method (Changed - Password parameter)
        SaveAs - Method (Changed - Password parameter)
IAcadApplication (Changed)
        HWND - Property (New)
IAcadPreferencesFiles (Changed)
        LicenseServer - Property (Changed to hidden)
        ObjectARXPath - Property (Changed to hidden)
        ColorBookPath - Property (New)
        ToolPalettePath - Property (New)
IAcadPreferencesUser (Changed)
        SCMTimeMode - Property (New)
        SCMTimeValue - Property (New)
IAcadDocuments (Changed)
GMT+8, 2026-10-23 08:28
