AutoCAD 2023 API 历史记录参考 (ActiveX)
对 AutoCAD 2023 和基于 AutoCAD 2023 的产品中的 ActiveX API 所做的添加和更改。 类AcadApplication
Minor version number of the class has been incremented from 24.1 to 24.2
Use the ProgID AutoCAD.Application.24.2 to create an instance of AutoCAD 2023, ProgID AutoCAD.Application.24.1 to create an instance of AutoCAD 2022, or
ProgID AutoCAD.Application.24.0 to create an instance of AutoCAD 2021, when installed.
ProgID AutoCAD.Application.24 can still be used to create an instance of AutoCAD 2023, but
there will be inconsistencies in execution when installed side-by-side with AutoCAD 2022 or AutoCAD 2021.
相关概念 |
GMT+8, 2026-10-24 17:35
