示例:访问图形特性 (AutoLISP/ActiveX)
该接口可作为 Document 对象的属性访问,以访问图形属性,如标题、主题、作者和关键字。IAcadSummaryInfo 注意:AutoCAD for Mac 不支持 ActiveX。
在以下示例中,该接口用于向当前图形添加标准属性和自定义属性:IAcadSummaryInfo (vl-load-com)
(defun c:ADD_PROPS (/ doc db si author nc nc2 nc3 value3 value4)
(setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(setq db (vla-get-Database doc))
(setq si (vla-get-SummaryInfo db))
(vla-put-author si "John")
(vla-put-comments si "New comments")
(vla-put-hyperlinkbase si "https://www.autodesk.com")
(vla-put-keywords si "New keywords")
(vla-AddCustomInfo si "siPutKey" "siPutValue")
(setq nc (vla-numcustominfo si))
(vla-SetCustomByKey si "siPutKey" "siPutValueByKey")
(vla-GetCustomByKey si "siPutKey" 'value3)
(if (/= "siPutValueByKey" value3)
(princ "*** Error SetCustomByKey\n")
(vla-SetCustomByIndex si (1- nc) "siPutCustomByIndexKey" "siPutCustomByIndexValue")
(vla-GetCustomByKey si "siPutCustomByIndexKey" 'value4)
(if (/= "siPutCustomByIndexValue" value4)
(princ "*** Error SetCustomByIndex\n")
(vla-RemoveCustomByIndex si (1- nc))
(setq nc2 (vla-numcustominfo si))
(if (/= nc2 (1- nc))
(princ "*** Error RemoveCustomByIndex")
; Remove property
(vla-RemoveCustomByKey si "siPutKey")
(setq nc3 (vla-numcustominfo si))
(princ "*** Error RemoveCustomByKey")
(vlax-release-object si)
(vlax-release-object db)
(vlax-release-object doc)
(princ)
(princ)
可以使用接口读取图形属性,如以下示例所示:IAcadSummaryInfo (vl-load-com)
(defun c:GET_PROPS (/ doc db si author )
(if (/= "MyDrawing.dwg" (getvar "DWGNAME"))
(princ "Open MyDrawing.dwg")
(progn
(princ "\nAuthor: \n")
(if (/= "John" (setq author (vla-get-author si)))
(princ "*** vla-get-author error")
(princ author)
(princ "\n")
(princ "\nComments:\n ")
(princ (vla-get-comments si))
(princ "\n")
(princ "\nHyperlink-base: \n")
(princ (vla-get-HyperlinkBase si))
(princ "\n")
(princ "\nNumber of custom properties: ")
(princ (setq nc (vla-numcustominfo si)))
(princ "\n")
(while (> nc 0)
(princ "Custom property ")
(princ nc)
(vla-GetCustomByIndex si (- nc 1) 'key 'value)
(princ ": key(")
(princ key)
(princ ")")
(princ " value(")
(princ value)
(princ ")\n")
(vla-GetCustomByKey si key 'value2)
(if (/= value value2)
(princ "\n*** Error GetCustomByKey returned unexpected result.\n")
(setq nc (1- nc))
(princ)
相关概念 |
GMT+8, 2026-10-23 09:14
