使用 AcGi 的示例
2024-5-18 18:50| 发布者: admin| 查看: 727| 评论: 0|原作者: admin|来自: AutoCAD
使用 AcGi 的示例
以下示例说明了如何使用 AcGi。首先,它保存颜色、线型和图层的当前实体属性值。然后,它将子实体特征颜色值更改为蓝色,并绘制一条三点折线。接下来,它将子实体特征颜色值更改为当前图层颜色,将线型值更改为 ,并绘制一条 xline。DASHDOT
示例代码包括两个函数 和 ,它们允许您从字符串中获取线型或图层的 ID。getLinetypeFromString()getLayerIdFromString()
注意:在实践中,这些函数可能太慢而无法在 中使用,应直接存储和使用对象 ID。worldDraw()
static Acad::ErrorStatus
getLinetypeIdFromString(const TCHAR* str, AcDbObjectId& id);
getLayerIdFromString(const TCHAR* str, AcDbObjectId& id);
 Adesk::Boolean
 AsdkTraitsSamp::subWorldDraw(AcGiWorldDraw* pW)
 // At this point, the current property traits are
 // the entity's property traits.  If the current
 // property traits are changed and you want to
 // reapply the entity's property traits, this is
 // the place to save them.
 Adesk::UInt16 entity_color
 = pW->subEntityTraits().color();
 AcDbObjectId  entity_linetype
 = pW->subEntityTraits().lineTypeId();
 AcDbObjectId  entity_layer
 = pW->subEntityTraits().layerId();
 // Override the current color and make it blue.
 pW->subEntityTraits().setColor(kBlue);
 // Draw a blue 3-point polyline.
 int num_pts = 3;
 AcGePoint3d *pVerts = new AcGePoint3d[num_pts];
 pVerts[0] = AcGePoint3d(0.0, 0.0, 0);
 pVerts[1] = AcGePoint3d(1.0, 0.0, 0);
 pVerts[2] = AcGePoint3d(1.0, 1.0, 0);
 pW->geometry().polyline(num_pts, pVerts);
 // Force the current color to use current layer's color.
 pW->subEntityTraits().setColor(kColorByLayer);
 // Force current line type to "DASHDOT".  If
 // "DASHDOT" is not loaded, the current line
 // type will still be in effect.
 AcDbObjectId dashdotId;
 if (getLinetypeIdFromString(_T("DASHDOT"), dashdotId)
 == Acad::eOk)
 pW->subEntityTraits().setLineType(dashdotId);
 // Force current layer to "MY_LAYER".  If
 // "MY_LAYER" is not loaded, the current layer
 // will still be in effect.
 AcDbObjectId layerId;
 if (getLayerIdFromString(_T("MY_LAYER"), layerId)
 == Acad::eOk)
 pW->subEntityTraits().setLayer(layerId);
 // Draw a dashdot'd xline in "MY_LAYER"'s color.
 pW->geometry().xline(pVerts[0], pVerts[2]);
 delete [] pVerts;
 return Adesk::kTrue;
 // A useful function that gets the linetype ID from the
 // linetype's name -- must be in upper case.
 Acad::ErrorStatus err;
 // Get the table of currently loaded linetypes.
 AcDbLinetypeTable *pLinetypeTable;
 err = acdbHostApplicationServices()->workingDatabase()
 ->getSymbolTable(pLinetypeTable, AcDb::kForRead);
 if (err != Acad::eOk)
 return err;
 // Get the id of the linetype with the name that
 // 'str' contains.
 err = pLinetypeTable->getAt(str, id, Adesk::kTrue);
 pLinetypeTable->close();
 return err;
 // A useful function that gets the layer ID from the
 // layer's name -- must be in upper case.
 // Get the table of currently loaded layers.
 AcDbLayerTable *pLayerTable;
 ->getSymbolTable(pLayerTable, AcDb::kForRead);
 return err;
 // Get the ID of the layer with the name that 'str'
 // contains.
 err = pLayerTable->getAt(str, id, Adesk::kTrue);
 pLayerTable->close();
 return err;
  1. 设置实体特征
GMT+8, 2026-11-15 12:48
