配置文件管理器示例
2024-5-18 18:50| 发布者: admin| 查看: 652| 评论: 0|原作者: admin|来自: AutoCAD
配置文件管理器示例
下面的示例演示了 and 类的用法:AcApProfileManagerAcApProfileManagerReactor
// Define a class derived from AcApProfileManagerReactor to manage
// the notifications.
class AsdkProfileManagerReactor : public AcApProfileManagerReactor
public:
    void currentProfileWillChange(const char *newProfile);
    void currentProfileChanged(const char *newProfile);
    void currentProfileWillBeReset(const char *curProfile);
    void currentProfileReset(const char *curProfile);
    void profileWillReset(const char *profName);
    void profileReset(const char *proName);
// Define the notification functions.
void
AsdkProfileManagerReactor::
    acutPrintf("\nCurrent profile will change: %s", newProfile);
void
    acutPrintf("\nCurrent profile changed: %s", newProfile);
void
    acutPrintf("\nCurrent profile will be reset: %s", curProfile);
void
    acutPrintf("\nCurrent profile has been reset: %s", curProfile);
void
    acutPrintf("\nNon-current profile will be reset: %s", profName);
void
profileReset(const char *profName)
    acutPrintf("\nNon-current profile has been reset:%s", profName);
void
aFunction()
    acutPrintf("This is AsdkProfileSample Test Application...\n");
    // Attach the reactor for the duration of this command. Normally
    // this would be added upon application initialization.
    AsdkProfileManagerReactor *pProfileRector =
        new AsdkProfileManagerReactor();
    acProfileManagerPtr()->addReactor(pProfileRector);
    // Obtain the path for the registry keys and print it out.
    char *pstrKey;
    acProfileManagerPtr()->ProfileRegistryKey(pstrKey, NULL);
    if (pstrKey != NULL) {
        acutPrintf("\nThe profiles registry key is: %s", pstrKey);
        acutDelString(pstrKey);
    // Get the list of all profiles in the user's configuration
    // and print them out.
    AcApProfileNameArray arrNameList;
    int nProfiles =
        acProfileManagerPtr()->ProfileListNames(arrNameList);
    acutPrintf("\nNumber of profiles currently "
        "in the user profile list is: %d", nProfiles);
    for (int i = 0; i < nProfiles; i++)
        acutPrintf("\nProfile name is: %s", arrNameList[i]);
    // Copy the unnamed profile to the AsdkTestProfile.
    acProfileManagerPtr()->ProfileCopy(
        "AsdkTestProfile",
        "<<Unnamed Profile>>",
        "This is a test");
    // Reset the newly copied profile to AutoCAD defaults.
    acProfileManagerPtr()->ProfileReset("AsdkTestProfile");
    // Make this new profile current.
    acProfileManagerPtr()->ProfileSetCurrent("AsdkTestProfile");
    // Change a value in the profile. For this example, make the
    // cursor big.
    struct resbuf rbCursorSize;
    rbCursorSize.restype = RTSHORT;
    rbCursorSize.resval.rint = 100;
    acedSetVar("CURSORSIZE", &rbCursorSize);
    // Rename the profile to a new name.
    acProfileManagerPtr()->ProfileRename(
        "AsdkTestProfile2",
        "AsdkTestProfile",
        "This is another test");
    // Export the profile.
    acProfileManagerPtr()->ProfileExport(
        "AsdkTestProfile2",
        "./AsdkTestProfile2.arg");
    // Import the profile.
    acProfileManagerPtr()->ProfileImport(
        "AsdkTestProfile3",
        "./AsdkTestProfile2.arg",
        "This is a copy of AsdkTestProfile2"
        "by Exporting/Importing",
        Adesk::kTrue);
    // Remove the reactor.
    acProfileManagerPtr()->removeReactor(pProfileRector);
  1. 配置文件管理器
GMT+8, 2026-11-15 14:34
