使用数据库反应器
下面的示例使用派生自 的 reactor 来跟踪数据库中当前对象的数量。它为 reactor 类实现了三个通知函数:、 和 。该函数将反应器添加到当前数据库。该函数从数据库中删除反应器并删除数据库反应器。AcDbDatabase-ReactorobjectAppended()objectModified()objectErased()watch_db()clear_reactors() class AsdkDbReactor;
long gEntAcc = 0; // Global entity count
AsdkDbReactor *gpDbr = NULL; // Pointer to database reactor
// Custom AcDbDatabaseReactor class for database
// event notification.
class AsdkDbReactor : public AcDbDatabaseReactor
public:
virtual void objectAppended(const AcDbDatabase* dwg,
const AcDbObject* dbObj);
virtual void objectModified(const AcDbDatabase* dwg,
virtual void objectErased(const AcDbDatabase* dwg,
const AcDbObject* dbObj, Adesk::Boolean pErased);
// Called whenever an object is added to the database.
void
AsdkDbReactor::objectAppended(const AcDbDatabase* db,
const AcDbObject* pObj)
printDbEvent(pObj, "objectAppended");
acutPrintf(" Db==%lx\n", (long) db);
gEntAcc++;
acutPrintf("Entity Count = %d\n", gEntAcc);
// Called whenever an object in the database is modified.
void
AsdkDbReactor::objectModified(const AcDbDatabase* db,
printDbEvent(pObj, "objectModified");
// Called whenever an object is erased from the database.
void
AsdkDbReactor::objectErased(const AcDbDatabase* db,
const AcDbObject* pObj, Adesk::Boolean pErased)
if (pErased) {
printDbEvent(pObj, "objectErased");
gEntAcc--;
} else {
printDbEvent(pObj, "object(Un)erased");
gEntAcc++;
// Prints the message passed in by pEvent; then
// calls printObj() to print the information about
// the object that triggered the notification.
void
printDbEvent(const AcDbObject* pObj, const char* pEvent)
acutPrintf(" Event: AcDbDatabaseReactor::%s ", pEvent);
printObj(pObj);
// Prints out the basic information about the object pointed
// to by pObj.
void
printObj(const AcDbObject* pObj)
if (pObj == NULL) {
acutPrintf("(NULL)");
return;
AcDbHandle objHand;
char handbuf[17];
// Gets the handle as a string.
pObj->getAcDbHandle(objHand);
objHand.getIntoAsciiBuffer(handbuf);
acutPrintf(
"\n (class==%s, handle==%s, id==%lx, db==%lx)",
pObj->isA()->name(), handbuf,
pObj->objectId().asOldId(), pObj->database());
// Adds a reactor to the database to monitor changes.
// This can be called multiple times without any ill
// effect because subsequent calls are ignored.
void
watchDb()
if (gpDbr == NULL) {
gpDbr = new AsdkDbReactor();
acdbHostApplicationServices()->workingDatabase()->addReactor(
gpDbr);
acutPrintf(
" Added Database Reactor to "
"acdbHostApplicationServices()->workingDatabase().\n");
// Removes the database reactor.
void
clearReactors()
if (acdbHostApplicationServices()->workingDatabase() != NULL) {
)->removeReactor(gpDbr);
delete gpDbr;
gpDbr = NULL;
// ObjectARX entry point function
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appId)
switch (msg) {
case AcRx::kInitAppMsg:
acrxDynamicLinker->unlockApplication(appId);
acrxDynamicLinker->registerAppNotMDIAware(appId);
acedRegCmds->addCommand("ASDK_NOTIFY_TEST",
"ASDK_WATCH",
"WATCH",
ACRX_CMD_TRANSPARENT,
watchDb);
"ASDK_CLEAR",
"CLEAR",
clearReactors);
break;
case AcRx::kUnloadAppMsg:
clearReactors();
acedRegCmds->removeGroup("ASDK_NOTIFY_TEST");
break;
return AcRx::kRetOK;
父主题: |
GMT+8, 2026-11-15 12:02
