创建引线 (.NET)
可以从图形中的任何点或特征创建引线并控制其外观。引线可以是直线段或平滑样条曲线。引线颜色由当前尺寸线颜色控制。引线刻度由活动维度样式中设置的整体维度刻度控制。箭头的类型和大小(如果存在)由活动样式中定义的箭头控制。 一条称为钩线的小线通常将注释连接到引线。如果最后一个引线段与水平线的角度大于 15 度,则挂钩线将显示多行文本和要素控制框。钩线是单个箭头的长度。如果引线没有注释,则它没有钩线。 ![]() 您可以通过创建 Leader 对象的实例来创建 Leader。创建 Leader 对象的实例时,其构造函数不接受任何参数。该方法用于定义所创建引线的位置和长度。AppendVertex 创建引线本示例在模型空间中创建引线。没有与引线关联的注释。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("CreateLeader")> _
Public Sub CreateLeader()
'' Get the current database
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create the leader
Using acLdr As Leader = New Leader()
acLdr.AppendVertex(New Point3d(0, 0, 0))
acLdr.AppendVertex(New Point3d(4, 4, 0))
acLdr.AppendVertex(New Point3d(4, 5, 0))
acLdr.HasArrowHead = True
'' Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acLdr)
acTrans.AddNewlyCreatedDBObject(acLdr, True)
End Using
'' Commit the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("CreateLeader")]
public static void CreateLeader()
// Get the current database
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create the leader
using (Leader acLdr = new Leader())
acLdr.AppendVertex(new Point3d(0, 0, 0));
acLdr.AppendVertex(new Point3d(4, 4, 0));
acLdr.AppendVertex(new Point3d(4, 5, 0));
acLdr.HasArrowHead = true;
// Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acLdr);
acTrans.AddNewlyCreatedDBObject(acLdr, true);
// Commit the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub CreateLeader()
Dim leaderObj As AcadLeader
Dim points(0 To 8) As Double
Dim leaderType As Integer
Dim annotationObject As AcadObject
points(0) = 0: points(1) = 0: points(2) = 0
points(3) = 4: points(4) = 4: points(5) = 0
points(6) = 4: points(7) = 5: points(8) = 0
leaderType = acLineWithArrow
Set annotationObject = Nothing
' Create the leader object in model space
Set leaderObj = ThisDrawing.ModelSpace. _
AddLeader(points, annotationObject, leaderType)
ZoomAll
相关概念父主题: |
GMT+8, 2026-11-15 12:49
