对齐单行文本 (.NET)
2024-5-18 18:48| 发布者: admin| 查看: 592| 评论: 0|原作者: admin|来自: AutoCAD
对齐单行文本 (.NET)
您可以水平和垂直对齐单行文本。左对齐是默认设置。若要设置水平和垂直对齐选项,请使用 和 属性。HorizontalModeVerticalMode
通常,当文本对象关闭时,会根据其对齐方式和文本样式调整文本对象的位置和对齐点。但是,内存中文本对象的对齐方式不会自动更新。调用该方法以根据文本对象的当前属性值更新其对齐方式。AdjustAlignment
重新对齐文本
下面的示例创建一个单行文本 () 对象和一个点 () 对象。点对象设置为文本对齐点,并更改为红色十字准线,以便可见。更改文本对齐方式并显示一个消息框,以便停止宏执行。这使您可以查看更改文本对齐方式的影响。DBTextDBPoint
VB.NET
<CommandMethod("TextAlignment")> _
Public Sub TextAlignment()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        Dim textString(0 To 2) As String
        textString(0) = "Left"
        textString(1) = "Center"
        textString(2) = "Right"
        Dim textAlign(0 To 2) As Integer
        textAlign(0) = TextHorizontalMode.TextLeft
        textAlign(1) = TextHorizontalMode.TextCenter
        textAlign(2) = TextHorizontalMode.TextRight
        Dim acPtIns As Point3d = New Point3d(3, 3, 0)
        Dim acPtAlign As Point3d = New Point3d(3, 3, 0)
        Dim nCnt As Integer = 0
        For Each strVal As String In textString
            '' Create a single-line text object
            Using acText As DBText = New DBText()
                acText.Position = acPtIns
                acText.Height = 0.5
                acText.TextString = strVal
                '' Set the alignment for the text
                acText.HorizontalMode = textAlign(nCnt)
                If acText.HorizontalMode <> TextHorizontalMode.TextLeft Then
                    acText.AlignmentPoint = acPtAlign
                End If
                acBlkTblRec.AppendEntity(acText)
                acTrans.AddNewlyCreatedDBObject(acText, True)
            End Using
            '' Create a point over the alignment point of the text
            Using acPoint As DBPoint = New DBPoint(acPtAlign)
                acPoint.ColorIndex = 1
                acBlkTblRec.AppendEntity(acPoint)
                acTrans.AddNewlyCreatedDBObject(acPoint, True)
                '' Adjust the insertion and alignment points
                acPtIns = New Point3d(acPtIns.X, acPtIns.Y + 3, 0)
                acPtAlign = acPtIns
            End Using
            nCnt = nCnt + 1
        Next
        '' Set the point style to crosshair
        Application.SetSystemVariable("PDMODE", 2)
        '' Save the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
[CommandMethod("TextAlignment")]
public static void TextAlignment()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        string[] textString = new string[3];
        textString[0] = "Left";
        textString[1] = "Center";
        textString[2] = "Right";
        int[] textAlign = new int[3];
        textAlign[0] = (int)TextHorizontalMode.TextLeft;
        textAlign[1] = (int)TextHorizontalMode.TextCenter;
        textAlign[2] = (int)TextHorizontalMode.TextRight;
        Point3d acPtIns = new Point3d(3, 3, 0);
        Point3d acPtAlign = new Point3d(3, 3, 0);
        int nCnt = 0;
        foreach (string strVal in textString)
            // Create a single-line text object
            using (DBText acText = new DBText())
                acText.Position = acPtIns;
                acText.Height = 0.5;
                acText.TextString = strVal;
                // Set the alignment for the text
                acText.HorizontalMode = (TextHorizontalMode)textAlign[nCnt];
                if (acText.HorizontalMode != TextHorizontalMode.TextLeft)
                    acText.AlignmentPoint = acPtAlign;
                acBlkTblRec.AppendEntity(acText);
                acTrans.AddNewlyCreatedDBObject(acText, true);
            // Create a point over the alignment point of the text
            using (DBPoint acPoint = new DBPoint(acPtAlign))
                acPoint.ColorIndex = 1;
                acBlkTblRec.AppendEntity(acPoint);
                acTrans.AddNewlyCreatedDBObject(acPoint, true);
                // Adjust the insertion and alignment points
                acPtIns = new Point3d(acPtIns.X, acPtIns.Y + 3, 0);
                acPtAlign = acPtIns;
            nCnt = nCnt + 1;
        // Set the point style to crosshair
        Application.SetSystemVariable("PDMODE", 2);
        // Save the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub TextAlignment()
    ThisDrawing.SetVariable "PDMODE", 2
    Dim textObj As AcadText
    Dim pointObj As AcadPoint
    ' Define the text strings and insertion point for the text objects
    textAlign(0) = acAlignmentLeft
    textAlign(1) = acAlignmentCenter
    textAlign(2) = acAlignmentRight
    insertionPoint(0) = 3: insertionPoint(1) = 0: insertionPoint(2) = 0
    Dim alignmentPoint(0 To 2) As Double
    alignmentPoint(0) = 3: alignmentPoint(1) = 0: alignmentPoint(2) = 0
    Dim nCnt As Integer
    For Each strVal In textString
        ' Create the Text object in model space
        Set textObj = ThisDrawing.ModelSpace. _
                        AddText(strVal, insertionPoint, 0.5)
        textObj.Alignment = textAlign(nCnt)
        On Error Resume Next
        textObj.TextAlignmentPoint = alignmentPoint
        Set pointObj = ThisDrawing.ModelSpace.AddPoint(alignmentPoint)
        pointObj.color = acRed
        insertionPoint(1) = insertionPoint(1) + 3
        alignmentPoint(1) = insertionPoint(1)
        nCnt = nCnt + 1
    Next
GMT+8, 2026-11-15 12:49
