创建单行文本 (.NET)
2024-5-18 18:48| 发布者: admin| 查看: 780| 评论: 0|原作者: admin|来自: AutoCAD
创建单行文本 (.NET)
使用单行文本时,每行文本都是一个不同的对象。要创建单行文本对象,请创建对象的实例,然后将其添加到表示模型或图纸空间的块表记录中。创建对象的新实例时,不会向构造函数传递任何参数。DBTextDBText
创建行文本
下面的示例在模型空间的坐标 (2, 2, 0) 处创建一个高度为 0.5 且文本字符串为“Hello, World”的单行文本对象。
VB.NET
<CommandMethod("CreateText")> _
Public Sub CreateText()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a single-line text object
        Using acText As DBText = New DBText()
            acText.Position = New Point3d(2, 2, 0)
            acText.Height = 0.5
            acText.TextString = "Hello, World."
            acBlkTblRec.AppendEntity(acText)
            acTrans.AddNewlyCreatedDBObject(acText, True)
        End Using
        '' Save the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
[CommandMethod("CreateText")]
public static void CreateText()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a single-line text object
        using (DBText acText = new DBText())
            acText.Position = new Point3d(2, 2, 0);
            acText.Height = 0.5;
            acText.TextString = "Hello, World.";
            acBlkTblRec.AppendEntity(acText);
            acTrans.AddNewlyCreatedDBObject(acText, true);
        // Save the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub CreateText()
    Dim textObj As AcadText
    Dim textString As String
    Dim height As Double
    ' Create the text object
    textString = "Hello, World."
    insertionPoint(0) = 2
    insertionPoint(1) = 2
    insertionPoint(2) = 0
    height = 0.5
    Set textObj = ThisDrawing.ModelSpace. _
                      AddText(textString, insertionPoint, height)
    textObj.Update
GMT+8, 2026-11-15 12:44
