对图层和线型进行排序 (.NET)
2024-5-18 18:48| 发布者: admin| 查看: 651| 评论: 0|原作者: admin|来自: AutoCAD
对图层和线型进行排序 (.NET)
您可以循环访问“图层”(Layers) 和“线型”(Linetypes) 表格,以查找图形中的所有图层和线型。
循环访问“图层”(Layers) 表
下面的代码循环访问“层”表,以收集图形中所有层的名称。然后,这些名称将显示在消息框中。
VB.NET
<CommandMethod("DisplayLayerNames")> _
Public Sub DisplayLayerNames()
    '' Start a transaction
        '' Open the Layer table for read
        Dim acLyrTbl As LayerTable
        acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
                                     OpenMode.ForRead)
        Dim sLayerNames As String = ""
        For Each acObjId As ObjectId In acLyrTbl
            Dim acLyrTblRec As LayerTableRecord
            acLyrTblRec = acTrans.GetObject(acObjId, _
                                            OpenMode.ForRead)
            sLayerNames = sLayerNames & vbLf & acLyrTblRec.Name
        Next
        Application.ShowAlertDialog("The layers in this drawing are: " & _
                                    sLayerNames)
        '' Dispose of the transaction
    End Using
C#
[CommandMethod("DisplayLayerNames")]
public static void DisplayLayerNames()
    // Start a transaction
        // Open the Layer table for read
        LayerTable acLyrTbl;
                                        OpenMode.ForRead) as LayerTable;
        string sLayerNames = "";
        foreach (ObjectId acObjId in acLyrTbl)
            LayerTableRecord acLyrTblRec;
                                            OpenMode.ForRead) as LayerTableRecord;
            sLayerNames = sLayerNames + "\n" + acLyrTblRec.Name;
        Application.ShowAlertDialog("The layers in this drawing are: " +
                                    sLayerNames);
        // Dispose of the transaction
VBA/ActiveX 代码参考
    Dim layerNames As String
    Dim entry As AcadLayer
    layerNames = ""
    For Each entry In ThisDrawing.Layers
        layerNames = layerNames + entry.Name + vbCrLf
    Next
    MsgBox "The layers in this drawing are: " + _
           vbCrLf + layerNames
GMT+8, 2026-11-15 11:39
