PostDatabaseProcessing 方法 (ActiveX/ATO)
2024-5-18 18:48| 发布者: admin| 查看: 666| 评论: 0|原作者: admin|来自: AutoCAD
在处理数据库后触发。
命名空间:传输塔利布
程序集: acETransmit20.tlb
VB.NET:
Friend Class custom_class_name
    Implements TransmittalDatabaseNotificationHandler
    Public Function postDatabaseProcessing(pDatabase As Object, _
                                           pFile As TransmittalFile, _
                                           pTransmit As TransmittalOperation) _
                                       As Integer _
                 Implements ITransmittalDatabaseNotificationHandler.postDatabaseProcessing
    End Function
End Class
C#:
internal class custom_class_name : TransmittalDatabaseNotificationHandler
     public int postDatabaseProcessing(object pDatabase,
                                       TransmittalFile pFile,
                                       TransmittalOperation pTransmit)
        return RetVal;
custom_class_name
自定义类的名称。
p数据库
访问:仅输入
类型:对象
指向已处理对象的指针。AcadDatabase
p文件
访问:仅输入
类型:TransmittalFile 对象
指向包含有关存储数据库的图形文件的信息的对象的指针。TransmittalFile
p传输
访问:仅输入
类型:TransmittalOperation 对象
指向表示包含图形文件的传递集的对象的指针。TransmittalOperation
返回值 (RetVal)
类型:整数
  • 0 (): 数据库未修改False
  • 1 (): 数据库已修改True
发行信息
释放:AutoCAD 2005 及更高版本
VB.NET:
' Custom class used to monitor the processing of a drawing
Friend Class MyTransDbNotifier
                                           pFile As TRANSMITTALLib.TransmittalFile, _
                                           pTransmit As TRANSMITTALLib.TransmittalOperation) _
                                       As Integer _
                 Implements TRANSMITTALLib. _
        Application.DocumentManager.MdiActiveDocument.Editor. _
            WriteMessage(Environment.NewLine & "Database post processing: " & pFile.sourcePath)
        Return 1
    End Function
End Class
C#:
// Custom class used to monitor the processing of a drawing
internal class MyTransDbNotifier : TransmittalDatabaseNotificationHandler
    public int postDatabaseProcessing(object pDatabase, TRANSMITTALLib.TransmittalFile pFile,
                                        TRANSMITTALLib.TransmittalOperation pTransmit)
            WriteMessage(Environment.NewLine + "Database post processing: " + pFile.sourcePath);
        return 1;
GMT+8, 2026-11-15 12:35
