AddSheets 方法 (ActiveX/ATO)
2024-5-18 18:48| 发布者: admin| 查看: 834| 评论: 0|原作者: admin|来自: AutoCAD
将图纸集 (DST) 文件中的文件添加到传递集。
命名空间:传输塔利布
程序集: acETransmit20.tlb
VB.NET:
object.addSheets sheets, includeSSFiles
C#:
object.addSheets(sheets, includeSSFiles);
类型:TransmittalOperation 对象
此方法应用到的对象。
床单
访问:仅输入
类型:对象数组AcSmSheet
对象在库中定义。AcSmSheetAcSmComponents
includeSS软件
访问:仅输入
类型:长
  • 0 (): 不包括 DST 文件引用的工作表集 (DST) 和支持文件False
  • 1 ():包括 DST 文件引用的工作表集 (DST) 和支持文件True
返回值 (RetVal)
无返回值。
发行信息
释放:AutoCAD 2005 及更高版本
历史
  • 该界面已与 AutoCAD 2010 版库中的界面合并。ITransmittalOperation2ITransmittalOperation
  • 该方法是在 AutoCAD 2005 版本的库中引入的。addSheetsITransmittalOperation2
VB.NET:
' Custom command to create a transmittal package from the sheets in a sheet set
<CommandMethod("eTransmitDSTFile_Sheets")> _
Public Shared Sub eTransmitDSTFile_Sheets()
    Dim ti As TransmittalInfo = _
        TransInfo(tro.getTransmittalInfoInterface(), "C:\Users\Public\TransmittalAPITest\")
    ' Add a sheet selection set from a sheet set and
    ' the drawings contained in it
    ' Get a reference to the Sheet Set Manager object
    Dim sheetSetManager As IAcSmSheetSetMgr = New AcSmSheetSetMgr
    ' Open a Sheet Set file
    Dim sheetSetDatabase As AcSmDatabase = _
        sheetSetManager.OpenDatabase("C:\AutoCAD\Sample\Sheet Sets\Architectural\IRD Addition.dst", False)
    ' Get the enumerator for the objects in the
    ' sheet set and then set the first object
    Dim enumerator As IAcSmEnumPersist = sheetSetDatabase.GetEnumerator()
    Dim itemSheetSet As IAcSmPersist = enumerator.Next()
    Dim sheetNames(0) As String
    Dim sheetSetSelOrSheetName As String = "T-01 TITLE SHEET;A-01 MAIN AND SECOND FLOOR PLAN"
    ' Semi-colon detected, multiple sheet names are being passed
    If sheetSetSelOrSheetName.Contains(";") = True Then
        sheetNames = sheetSetSelOrSheetName.Split(";")
    Else
        sheetNames(0) = sheetSetSelOrSheetName
    End If
    ' Create an array of the sheets based on their names
    Dim sheetArray(0) As IAcSmObjectId
    Dim sheet As AcSmSheet, nCount As Integer = 0
    ' Step through the objects in the sheet set
    Do While Not itemSheetSet Is Nothing
        ' Check to see if the object is a Sheet
        If itemSheetSet.GetTypeName() = "AcSmSheet" Then
            ' A sheet was found, now to see if it is the one needed
            sheet = itemSheetSet
            ' Step through each name provided
            For Each sheetName As String In sheetNames
                ' Check to see if the sheet name matches the sheet
                If UCase(sheet.GetName()).Equals(UCase(sheetName)) = True Then
                    ReDim Preserve sheetArray(0 To nCount)
                    ' Match was found, add the sheet's object Id to the array
                    sheetArray(nCount) = sheet.GetObjectId()
                    ' Increment the counter by 1
                    nCount = nCount + 1
                End If
            Next
        End If
        ' Get the next object
        itemSheetSet = enumerator.Next()
    Loop
    ' Get the sheets from the database and process them
    ' 0 - Do not include DST file or support files referenced
    '     by the DST file (templates, blocks, ...)
    ' 1 - Include DST file, all files referenced by the
    '     DST file, its sheets and references
    If sheetArray.Length > 0 And sheetArray(0).Equals("") = False Then
        tro.addSheets(sheetArray, vbTrue)
    End If
    ' Close the sheet set
    sheetSetManager.Close(sheetSetDatabase)
    ' Create the transmittal package
    ' Files are copied and resaved to the path specified by the destinationRoot property
    ' and the other settings of the TransmittalInfo object.
    tro.createTransmittalPackage()
C#:
// Custom command to create a transmittal package from the sheets in a sheet set
[CommandMethod("eTransmitDSTFile_Sheets")]
public static void eTransmitDSTFile_Sheets()
    TransmittalInfo ti =
        TransInfo(tro.getTransmittalInfoInterface(), "C:\\Users\\Public\\TransmittalAPITest\\");
    // Add a sheet set and the drawings referenced in it
    // Get a reference to the Sheet Set Manager object
    IAcSmSheetSetMgr sheetSetManager = new AcSmSheetSetMgr();
    // Open a sheet set (DST) file
    AcSmDatabase sheetSetDatabase =
        sheetSetManager.OpenDatabase("C:\\AutoCAD\\Sample\\Sheet Sets\\Architectural\\IRD Addition.dst", false);
    // Get the enumerator for the objects in the
    // sheet set and then set the first object
    IAcSmEnumPersist enumerator = sheetSetDatabase.GetEnumerator();
    IAcSmPersist itemSheetSet = enumerator.Next();
    string[] sheetNames = new string[1];
    string sheetSetSelOrSheetName = "T-01 TITLE SHEET;A-01 MAIN AND SECOND FLOOR PLAN";
    // Semi-colon detected, multiple sheet names are being passed
    if (sheetSetSelOrSheetName.Contains(";") == true)
        sheetNames = sheetSetSelOrSheetName.Split(';');
    else
        sheetNames[0] = sheetSetSelOrSheetName;
    // Create an array of the sheets based on their names
    IAcSmObjectId[] sheetArray = new IAcSmObjectId[1];
    AcSmSheet sheet = default(AcSmSheet);
    int nCount = 0;
    // Step through the objects in the sheet set
    while (itemSheetSet != null)
        // Check to see if the object is a Sheet
        if (itemSheetSet.GetTypeName() == "AcSmSheet")
            // A sheet was found, now to see if it is the one needed
            sheet = (AcSmSheet)itemSheetSet;
            // Step through each name provided
            foreach (string sheetName in sheetNames)
                // Check to see if the sheet name matches the sheet
                if (sheet.GetName().ToUpper().Equals(sheetName.ToUpper()) == true)
                    Array.Resize(ref sheetArray, nCount + 1);
                    // Match was found, add the sheet's object Id to the array
                    sheetArray[nCount] = sheet.GetObjectId();
                    // Increment the counter by 1
                    nCount = nCount + 1;
        // Get the next object
    // Get the sheets from the database and process them
    // 0 - Do not include DST file or support files referenced
    //     by the DST file (templates, blocks, ...)
    // 1 - Include DST file, all files referenced by the
    //     DST file, its sheets and references
    if (sheetArray.Length > 0 & sheetArray[0].Equals("") == false)
        tro.addSheets(sheetArray, 1);
    // Close the sheet set
    sheetSetManager.Close(sheetSetDatabase);
    // Create the transmittal package
    // Files are copied and resaved to the path specified by the destinationRoot property
    // and the other settings of the TransmittalInfo object.
    tro.createTransmittalPackage();
GMT+8, 2026-11-15 13:57
