IndexOf 方法 (ActiveX)
2024-5-18 18:46| 发布者: admin| 查看: 862| 评论: 0|原作者: admin|来自: AutoCAD
提供“文件依赖项列表”中条目的索引。(已过时)
RetVal = object.IndexOf(Feature, FullFileName)
类型:FileDependencies
此方法应用到的对象。
特征
访问:仅输入
类型:字符串
条目的功能名称。
完整文件名
访问:仅输入
类型:字符串
条目的完整路径。
返回值 (RetVal)
类型:长
条目的索引。
发行信息
释放:AutoCAD 2000 到 AutoCAD 2017
Sub Example_IndexOf()
    'This example adds an entry to the File Dependency List, returns its Index, updates
    'the entry, and then removes the entry.
    ThisDrawing.Application.Documents.Open ("c:\program files\autocad\sample\city map.dwg")
    Dim objFDLCol As AutoCAD.AcadFileDependencies
    Dim objFDL As AutoCAD.AcadFileDependency
    Set objFDLCol = ThisDrawing.FileDependencies
    MsgBox ("The number of entries in the File Dependency List is " & objFDLCol.Count & ".")
    Dim FDLIndex As Long
    FDLIndex = objFDLCol.CreateEntry("acad:xref", "c:\referenced.dwg", True, True)
    Dim IndexNumber As Long
    IndexNumber = objFDLCol.IndexOf("acad:xref", "c:\referenced.dwg")
    Dim IndexString As String
    IndexString = CStr(IndexNumber)
    MsgBox ("The index of the new entry is " & IndexString & ".")
    objFDLCol.UpdateEntry (FDLIndex)
    objFDLCol.RemoveEntry FDLIndex, True
(defun c:Example_IndexOf()
    ;; This example adds an entry to the File Dependency List, returns its Index, updates
    ;; the entry, and then removes the entry.
    (setq objFDLCol (vla-get-FileDependencies doc))
    (alert (strcat "The number of entries in the File Dependency List is " (itoa (vla-get-Count objFDLCol)) "."))
    (setq FDLIndex (vla-CreateEntry objFDLCol "acad:xref"
                                   (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\Exterior Elevations.dwg") :vlax-true :vlax-true))
    (setq IndexNumber (vla-IndexOf objFDLCol "acad:xref" (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\Exterior Elevations.dwg")))
    (alert (strcat "The index of the new entry is " (itoa IndexNumber) "."))
    (vla-UpdateEntry objFDLCol FDLIndex)
    (vla-RemoveEntry objFDLCol FDLIndex :vlax-true)
GMT+8, 2026-11-15 12:09
